Brass Radiator Plug - Defender Source
Old July 8th, 2010, 10:12 AM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
Brass Radiator Plug
Hi,
My radiator plug is plastic, and will need to be replaced at some point as the threads are starting to go. I have a couple friends with Brass Radiator Plugs in their Rovers.
One guy has a 1987 RR Classic.
One guy has a 1995 Discovery. His discovery had a plastic one. He replaced it with a brass on that he found in a junk yard in a 1988 RR Classic.
I know I can reorder the plastic radiator plug - and it obviously has lasted a long time - but I just thought I would post the question about Brass Plugs before I buy a new one?
Anyone have one, or have a lead?
Flagg
Old July 8th, 2010, 10:18 AM
Tony Brooks picked up a few a couple years back... Contact him. But, I think they are available at Home Depot or Lowes, as they are the same part as a HVAC component.
Old July 8th, 2010, 10:27 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Originally Posted by Flagg View Post
Hi,
Flagg
http://rovahfarm.com/defendercoolingpage2.htm - 4th item down
-Ren Ching
Old July 8th, 2010, 10:57 AM
Flagg's Avatar
Flagg
Flagg
Steve - AWESOME - I will be ordering one. Thanks for the lead!
Flagg
Old July 8th, 2010, 07:57 PM
smob's Avatar
smob
Steve
Flagg
No problem - bought one for 20 bucks from Expedition Exchange and then got another from Rovah Farm for 4 bucks. Sigh.
-Ren Ching
Old July 8th, 2010, 08:43 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Yah, I bought 30 or so of them from the UK in bulk and passed them through (won't do that again!).
I believe the threading is actually BSF which is REALLY close to the threading on the plumbing thread -- close enough to fit. The "real" ones are nice as many will take a socket as well as having a large slot to take a screwdriver shaft/leatherman etc.
Old November 16th, 2010, 10:54 AM
I have the EE brass plug which is great, but the O ring is leaking and needs replacement. Does anyone know the correct size O ring to replace it with? I wanted to hit up Home Depot, Lowes or NAPA to get a replacement ASAP, but obviously, once I'm there I can't pull it off to take it in and measure.
Old November 16th, 2010, 11:25 AM
The Dro
Dro
1988 Ninety
When I did my radiator a few months ago, I went to Advance Auto and got it from there. I think I paid $1 for it.
They have a shelf with several different sizes ask the guy if you can "try" them on.
------ Follow up post added November 16th, 2010 11:28 AM ------
also try ESR1594L
I've been meaning to try these guys and see if 3203-8-PLUG will work on your trucks
http://www.pegasusautoracing.com/pro...p?Product=3203
Old November 16th, 2010, 12:07 PM
I'm at napa now with plug pulled, and NAPA o ring 727-2616 is a perfect fit for EE's brass plug. $4 a piece.
Mark Kellgren
KM4BOR
Old November 16th, 2010, 12:35 PM
The Dro
Dro
1988 Ninety
For the seal?
Old November 16th, 2010, 12:46 PM
correct. new bun-n nitrile o ring that sits inside the brass plug seal cavity.
Old November 16th, 2010, 06:38 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
Hi.
Got mine from George at RDS. Make sure you get the o-rings also. Same plugs replace plastic fill plugs in the later Disco differential housings. For V8 EFI, you will need two -- one for the radiator and one for the cooling system bleed port.
radiator
Brass Radiator Plugs Abrooks For Sale - Parts 29 March 19th, 2017 11:23 PM
Ammo and brass FS stu454 The Flea Market 2 December 7th, 2009 03:09 PM
Brass radiator plug ERR4686 JFD Defender Technical Discussions 9 November 30th, 2009 09:10 PM
Brass Radiator Plug Billakris Defender Technical Discussions 18 May 11th, 2006 11:35 AM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
