Brake proportioning valve - Defender Source
Old April 14th, 2006, 07:09 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I need a D-90 Brake proportioning valve. THis is the valve that is bolted on the bulkhead. I don't know if these are on Disco's and RRC's or not.
Legend in My Own Mind.
Old April 14th, 2006, 03:40 PM
Paul Grant
Paul Grant
Randy,
I have one off a Range Rover. I'll just add it to the rest if the stuff I'm giving to Kevin for you. If it works, great, if not, maybe someday you'll own and old Range Rover!
Paul
Old April 14th, 2006, 06:13 PM
Shane@EVS
Roverhybrids
If the RRC doesn't work I have one from a D90
Old April 14th, 2006, 07:28 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ok. I will check the one off the RRC. If not how much for the D-90 one Shane? I should have just bought everything off your truck lol
brake
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
