brake master cylinder & front right caliper also a distribitor - Defender Source
Old June 18th, 2009, 10:17 AM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
looking for some parts guys to make the truck build dale knepp sold me driveable.
distibutor without vacuum advance.
3.9 motor
94 d90 brake system
i have some parts to trade if an option. just let me know what you are looking for.
thanks guys, would really like to drive this truck during the short summer season we have here.
WHO OWN THE CHIEFS? OWNZZZ OWNZZZ
my e-mail:
Old June 18th, 2009, 10:52 AM
btate
Bryan Tate
d90
pm sent
Old June 18th, 2009, 04:28 PM
mountainviewrover
MARK LECLAIR
Let Me Clear My Pm Box Sorry
my e-mail:
Old June 18th, 2009, 04:30 PM
I have a 3.9 motor. Cheap, PU only outside philly though.
Old June 19th, 2009, 08:43 AM
mountainviewrover
MARK LECLAIR
Sorry About The Confusion Ron. The Truck Has A 3.9 And A 94 D90 Brake System.
Just Need The Brake Master Cylinder And Caliper.
I Bought A Truck That Was Supposed To Be A Summer Runner. Can't Have A Runner Without Brakes.
my e-mail:
Old June 19th, 2009, 10:44 AM
Ah, New MC's are $150 or so and autozone has the calipers for under $100.
Old June 19th, 2009, 12:15 PM
mountainviewrover
MARK LECLAIR
Thanks Ron. The Truck Was Supposed To Have Working Power Brakes. It Has None. Friggin Bummin Me Out. Dale Is Not Taking Responsibility For It. He Offered To Split The Cost. What Bs. Don't Even Get Me Started On How Many Hours I Have In This Thing To Get Things Right.
Oh, Also Looking For Windshield Wipers And Motor. The Truck Came In With Out That Too. Really Need The Wiper Arms And Assy To Pass Inspection.
my e-mail:
Old June 19th, 2009, 04:09 PM
Does it have no power to the brakes or no brakes at all? If no power it is probably something stupid like a disconnected vacuum hose or a bad check valve and, in any event, would be the booster not the MC.
Take a picture of the brake assembly and post it and I will be able to tell what it is off of.
Old June 24th, 2009, 12:46 PM
mountainviewrover
MARK LECLAIR
Pictures
Ron I Think You Are Correct On The Booster.
I Have Enclosed A Picture.
Also, Check Out This Distributor With Vac. Advance. Doesn't Allow Me To Dial The Timing In.
Your Thoughts.
ID:	20226   Click image for larger version
my e-mail:
Old June 24th, 2009, 01:34 PM
Distributor looks pretty normal to me, as far as the brakes, follow the hose coming out of the booster next to the MC and see if it is broken or not hooked up to the manifold. If that checks out, replace the check valve that it is attached to. 90% sure that one of these two things is the problem.
What exactly is the issue with the vacuum advance? YOu can't adjust the distributor enough?
Old June 24th, 2009, 01:57 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
It looks like the issue is the avdance pot is hitting the back of the timing cover? I think you can install these distributors a notch off and this will happen? Been over a year since I had one of the distributors out, cant recall.
Old July 3rd, 2009, 09:22 AM
mountainviewrover
MARK LECLAIR
ron, hoses look good and are connected. check valve seems to hold pressure. no cracks on it. could a bad caliper cause this no brake problem? the front right caliper doesn't seem to move.
any help would be great.
thanks
my e-mail:
Old July 3rd, 2009, 06:34 PM
A dead caliper would not cause that problem. It would just cause pulling under braking.
brake, ht, master
Brake Master Cylinder Leak chris snell Defender Technical Discussions 12 September 28th, 2011 09:50 AM
front caliper brakeline jabber Defender Technical Discussions 5 May 3rd, 2009 11:31 AM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
