Boge Self-leveling unit - Defender Source
Old July 1st, 2016, 12:14 AM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
Hi folks,
In the process of attempting to rebuild my 110 self-leveling unit and it's clear that I have as close to zero chance as possible about removing the upper ball joint assembly. It's in there like a sonofabitch and can't get the nut spun off to release the ball joint.
So, I'm looking to source another bodge unit. Let me know what you've got!
Thanks!
-Eric
Old July 1st, 2016, 12:39 AM
TheOneTen's Avatar
TheOneTen
Eric Wages
I'd pull the whole A-Arm and do it out from under the truck.
-Jeff
Oh, the whole assembly is torn down off the truck I'm just looking to see if I can find something that's a little less questionable than my nearly 30-year old unit.
After much cursing, chiseling, and copious use of my MAP torch, I made progress on the upper ball joint, but I still need to get it out of the boge unit. Of course, it looks like I'll need to make some custom wrench to fit the tight space.
Old July 1st, 2016, 07:01 AM
Naplm00
Matthew
Heat to red and a good impact didn't do it? You an always use a grinder to cut a slot in the nut and chisel it off
Old July 1st, 2016, 08:30 AM
Thought the conventional wisdom on the Boge unit was to leave them off. Land Rover dropped it with no regrets.
Old July 1st, 2016, 04:47 PM
Actually they were a great idea and great to have. They were just too costly.
Old July 1st, 2016, 05:04 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
What's the preventive maintenance script on these things?
Old July 1st, 2016, 05:19 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
Prayer
Old July 1st, 2016, 05:21 PM
1of40's Avatar
1of40
1of40
Originally Posted by 16kpsi View Post
Prayer
ha! I hear prayer carpets also reflect heat and vibes.
Old July 2nd, 2016, 02:55 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Is this anything?:
https://www.zoro.com/proto-thin-patt...es/g/00108679/
And if you come up with a good confirmation for the size of that one very thin, but huge-diameter nut on the Boge, please post the size for posterity.
Old July 2nd, 2016, 05:34 PM
Found this bookmarked.
Download the PDF linked in the last paragraph.
http://www.roversd1.info/misc/suspension.html
NAS 110 Self Leveling suspension lordhelemt Defender Technical Discussions 5 May 17th, 2016 03:04 AM
Rear self-leveling unit. ajh Defender Technical Discussions 25 September 23rd, 2015 10:59 AM
FS brand new 110 STW Boge self levelling unit NRC7050 V8County For Sale - Parts 3 March 26th, 2014 06:00 AM
Opinions about Boge unit 16kpsi Defender Technical Discussions 8 October 29th, 2010 08:17 PM
Boge Unit removal Doug Defender Technical Discussions 15 September 14th, 2005 01:35 AM
