Blower motor - Defender Source
Old October 28th, 2007, 07:59 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Blower motor
Either working or not, non working probably better. Would like to have my electronics expert experiment with it. Must make it stronger, need more heat.
Tom
Old October 28th, 2007, 08:12 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
What about adding something like this inline to give it a boost?
Old October 28th, 2007, 08:24 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Tom, I found the biggest increase in heat I got was when I removed the plastic covers from the heat vents. Really increases the airflow by a big margin.
Also, I had a lot of drafts coming in from all the doors. Taking the time to adjust the striker plates for better sealing helped keep the cold out. Same with really making sure the dash vents are shut tight and have good seals on them.
Do you have a soft top or a hard top?
My oil line fix
My 100k stopped odometer fix
Old October 29th, 2007, 10:49 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Its an older hardtop 1985.
Where on LI are you located?
Old October 29th, 2007, 11:46 AM
Hans's Avatar
Hans
Hans Haase
Islip area.
My oil line fix
motor
'95/Wynn's A/C blower motor repair/replacement tgraham Defender Technical Discussions 12 June 3rd, 2016 03:40 PM
97 AC blower motor - one or two? artm Defender Technical Discussions 0 March 3rd, 2009 02:25 PM
A/c blower motor Campbell Defender Technical Discussions 1 September 27th, 2004 08:19 AM
A/C blower motor Campbell Defender Technical Discussions 3 September 9th, 2004 11:01 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
