Bits needed for 4.2 auto conversion - Defender Source
Old August 15th, 2014, 11:08 PM
Trey C
Trey Crowther
1983 V8 110 County
I need a v belt alternator from a fuel injected truck with the adjustment bar
Also need a power steering pump and mount bracket
lastly need the ring that bolts to the crank (and the pan head bolts that secure it)
that the 4 bolt spacer ring bolts to
actually need this part first/fastest as its keeping us from installing the lump
Old August 16th, 2014, 08:57 AM
bump for the crank ring that the spacer bolts to. Want to drop this lump in his truck
Old August 16th, 2014, 11:55 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Any chance you can show me an image of the part you are needing Doug for the flexplate arrangement. I have a bunch of those parts stacked up in a corner somewhere and hate to send the incorrect one.. May have the bolts also
Should have power steering bits as well. Have you got anything to trade?
legend in my own mind
Old August 16th, 2014, 01:03 PM
Jim,
We are going to make the trek back to the truck we pulled the trans from and get the bit on the back of the crank this afternoon. Its a 5hour drive round trip but its Newman's house and will be fun. Was sweating Trey to procure his own parts but as usual handled it for him. Its called a spacer/adapter ring and bolts to the back of the crank and the four spacer bolts that attach the flexplate and ring gear thread into it. We had all of that just not the ring and the allen head bolts that attach it.
Old August 16th, 2014, 10:58 PM
Thanks again Rick Newman for the parts and the cookout. Great way to spend a Saturday evening
Old August 17th, 2014, 07:57 AM
ezzzzzzz
Mark Garrenton
I thought you were talking about the front of the engine but couldn't figure out what you needed. I could have hooked you up with parts here. Oh well, Newman is way closer and their food is hard to beat. Rick gave me the bits needed off that RRC for Taylor's 4.0 build. Friends like Rick don't come any better!
Old August 17th, 2014, 08:16 AM
The 4.2 going in Trey's truck is the one I got from you Mark. Using the trans out of that Rangie and a 1.2 lt230Q I had sitting around. Going to stick with the edlebrock setup so it should be fun to kick it down and floor it.
Old August 17th, 2014, 10:57 AM
cbfritz_03
Carmen
none
I'm going to have to chime in on that about Rick. He is a great guy and has been the most supportive of me in my maiden rover voyage/addiction. Haven't met him in person yet, but I most definitely and proudly consider him a friend.
Old August 17th, 2014, 11:00 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Amen, Rick is as good as they come. Hands down one of the best.
Old August 17th, 2014, 11:24 AM
cbfritz_03
Carmen
none
Yup. He has built me up, talked me down, held my hand, set me straight, pissed me off and made me laugh. Great guy.
Old August 17th, 2014, 12:37 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Glad you got it sorted. Sometimes it helps to be pulling the parts you need in a situation like that.
conversion
Bits for IIA LHD conversion needed! JohnBullsBollocks Wanted 2 June 23rd, 2014 02:37 PM
Auto Conversion Idle Help mpsteil Defender Technical Discussions 12 February 10th, 2010 03:55 PM
90 to 110 Conversion Leftovers Bits Pricing Wolf Fabrication Defender Technical Discussions 4 July 12th, 2009 10:54 AM
93 D110 auto transmission conversion bcourtney Defender Technical Discussions 37 June 8th, 2007 08:37 PM
Manual To Auto Conversion willtillery Defender Technical Discussions 2 September 22nd, 2004 10:12 PM
