Best/Badger Top support bars needed - Defender Source
Old December 16th, 2010, 01:03 PM
2yellowlabs's Avatar
2yellowlabs
Rob
92 RRC, 99 DII, 06 LR3, 09 LR2
Need the support bars at the b-pillars. These go into the pockets at the door jambs. If these are not available could someone post pics and I'll try to fab them?
Also need a tailgate belt rail for the same. Have a Best-Top that is missing only these pieces to install.
Thank you in advance!
Thank you -
Rob
Old December 16th, 2010, 01:34 PM
I thought Badger had these items?
He used to have the horizontal bars with snaps (but I don't see it on his site now), but I believe the aluminum tailgate bar is still available.
http://www.badgercoachworks.com/index_files/Page879.htm
Old December 16th, 2010, 02:01 PM
You don't need the B-pillar things for a bestop. Only the later ones had them. Badger ones are different and for the gutter kit.
Tailgate bar kit is ~$80 from the usual suspects.
Old December 16th, 2010, 02:29 PM
He sells/sold those bars for those without the Gutter Kits as well...the Badgers with GK don't have snaps along there, only straps. Fairly certain the "five snap door bars" aka "horizontal bar" he had been selling were for those without the GK.
Old December 16th, 2010, 02:33 PM
2yellowlabs
Rob
Empty pockets
Really? The Best Top that came with the truck does have the pockets for them. Won't it flap around without them? What do they look like?
I'd like to get this one on so I can patch up the fiberglass top that is badly cracked and leaks H20 from everywhere!
Thanks!
Thank you -
Rob
Old December 16th, 2010, 02:53 PM
CDeWan
Clay DeWan
5.3L beastie
I with Rob on what those look like. I have a 95 best top and it has what appears to be places to slide bars through with - kind of like a vinly sleeve on the inside of the B pillar with a hole in th e top and bottom - vertical.
Old December 16th, 2010, 03:04 PM
2yellowlabs
Rob
Thanks! So you obviously run it without these bars then, yes? I don't know crap about these tops so it could be that there never were bars in there. If that's the case I guess I'm good to go then?
Thank you -
Rob
badger
needed: roll bar parts, tailgate, soft top bstraw Wanted 3 March 21st, 2006 10:01 AM
d90 hard top needed! johnsweeney Wanted 0 January 2nd, 2006 12:48 AM
Fiberglass Top Needed in Colorado boshea Wanted 3 December 8th, 2005 01:24 PM
Hard Top needed in Colorado snosrfr Wanted 19 November 15th, 2005 12:06 PM
cheap soft top needed DBZ2009 Wanted 10 January 24th, 2005 11:41 PM
