Axle brackets for front sway bar - Defender Source
Old June 2nd, 2013, 12:18 AM
Anyone got a spare housing and can sawzall them off? I don't feel like swapping housings and all my housings are pre-sway bar. I have the sway bar, I have the frame brackets, I just need the axle brackets to weld on.
Old June 2nd, 2013, 10:56 AM
Roving Beetle
Doug
Sure. I can plasma cut them off.... Just need to get the cutter back from my friend.
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
PM sent
Old June 2nd, 2013, 11:04 AM
jafir's Avatar
jafir
Jafir Elkurd
I'm putting d1 axles in my 90. They had anti-sway bars on them. Are d1 sways the same as d90 sways, if I wanted to add them?
Old June 2nd, 2013, 11:23 AM
I think so. You would need frame brackets.
Old June 2nd, 2013, 11:28 AM
jafir's Avatar
jafir
Jafir Elkurd
I've got the straps that bolt on around the bars and the bushings, if that's what you mean. Or is there some sort of bracket on the chassis I need to acquire and weld on? I was hoping I could just drill and tap some holes.
Old June 2nd, 2013, 11:49 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Its a really simple bracket, you could make yourself (or they could be cut off another chassis easily) and weld to the chassis but no you cant just drill tap holes. The straps/bushings you have cant mount flush to the frame they have to hang down a few inches.
defender resto porn photo for reference:
ignore the improper bulkhead mounting in the photo LOL- look at the bottom of the chassis just behind the front tires, the sway bar mounts to the rectangle. Looks like this= l___l
Old June 2nd, 2013, 11:53 AM
jafir's Avatar
jafir
Jafir Elkurd
Thanks!
Old June 2nd, 2013, 07:00 PM
Still looking. Maybe someone has a bent housing?
Old June 2nd, 2013, 07:11 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Check with YRM they have the anti roll brackets new
http://www.yrmlandrover.com/epages/B...jectID=3479796
Old June 2nd, 2013, 07:50 PM
For that price I will get a new axle!
fabbing sway bar mounts J.5 Defender Technical Discussions 1 September 13th, 2007 02:26 PM
rear sway bar for Guinness jabber For Sale - Parts 5 March 8th, 2005 10:45 AM
Sway Bar Disco Build blkdiscoII Misc. Chit-Chat 1 March 6th, 2005 02:10 PM
Sway Bar Disconnect mdmccallum Defender Technical Discussions 12 December 15th, 2004 08:20 PM
front sway bar mattdh Wanted 3 October 28th, 2003 09:23 PM
