auxiliary fuel tank - Defender Source
Old March 6th, 2011, 08:54 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
auxiliary fuel tank
looking for an auxiliary fuel tank for my '94 NAS d-90 (V8). Let me know if you have something....
Old March 6th, 2011, 09:10 PM
CDeWan
Clay DeWan
5.3L beastie
Tim,
Check with George at RDS. If you want any tips on putting one in, I had one installed on my 94. I cut the seat box out to make room for it. It is the U.K. type. I hooked up a sending unit to the tank and a switch so I could pump the gas from the aux tank into the filler neck of the main tank. I just watch the aux gas guage until it gets low and then turn it off. The hardest part was where to put the filler neck. Mine is installed under my pass. seat. I would not recommend that just becuase I had to take the truck back 2x to get the fumes from exporting into the cab. If I had to do it all over again I will put the filler neck externally and accesible from right in front of the rear tire. That way you won't have to cut into the body. You can also try ebay and ebay canada to get one of the tanks.
If you need pics., let me know.
Clay
Old March 6th, 2011, 10:25 PM
Rugbier's Avatar
Rugbier
Gustavo
If George doesn't have what you want, Justin (Lucky8) sells the Safari ones as well as the ones that goes on the seat box
NO SIGNATURE
Old March 7th, 2011, 01:30 AM
CDeWan
Clay DeWan
5.3L beastie
Gustavo,
Bought the gas tank protector from Justin .
Old March 7th, 2011, 07:48 AM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
I have seen the safari ones on their website. Do these hang below the frame? The under-seat one won't work...too much stuff in there already!
I'm willing to give up some capacity for something that fits up above or even with the frame.
Any ideas?
Old March 7th, 2011, 03:26 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Smile
I have one
Old March 7th, 2011, 04:36 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
a little more info please?
ANy pics of it mounted? Capacity? Etc...
Old March 7th, 2011, 05:20 PM
oldgreentrucks's Avatar
oldgreentrucks
Jim Pace
I installed a 9 gal Rover Accessories saddle tank years ago. Mounted under right side & does not hang below the frame. Brief description at http://imageevent.com/jimpace/landro...i3s911.camel_s
Happy with this set up. Not sure if still available due to the fun police. Glad to answer any questions.
Jim
Old March 7th, 2011, 05:33 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
nice setup. I'm looking for something similar to yours but they dont seem to be out there anymore.
Old March 7th, 2011, 10:09 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Saw an ad in a Rover magazine of a tank that fit behind the rear tire (yes, between the rear X member and the axle/tire). Seemed to be a great location since I assume you can reuse the filler neck and short plumbing to move fuel from one tank to the other. Not sure how it works exactly, just basing all my statement on a single low res picture.... I should probably look for the article so I can find a company name...
MonLand
1995 D90 NAS
1996 Discovery NAS
Old March 7th, 2011, 10:42 PM
Rugbier's Avatar
Rugbier
Gustavo
Originally Posted by CDeWan View Post
Gustavo,
Clay , Very Nice
NO SIGNATURE
Old March 7th, 2011, 10:47 PM
Rugbier's Avatar
Rugbier
Gustavo
Any ideas?
here is a pic of them mounted on Shrek
I will say the hang 2-3" lower ( in the pic looks lower as it was taken from below )
NO SIGNATURE
Old March 8th, 2011, 05:39 AM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
I have seen these too but if I remember correctly, they don't make them for the 90 (just the 110, 130) as there is not enough space. I hope I am wrong though as this would be perfect.
-T
Old March 8th, 2011, 07:05 AM
ron's Avatar
ron
Ron
tim give a call
781640 264zero
Old March 25th, 2011, 03:49 PM
MonLand
Loic Fabro
Finally got to post the picture:
http://www.facebook.com/photo.php?pi...&id=1007136705
Name of the (Swiss) company is in the picture.
Web site (German or French): http://www.safari-centre.com/index.p...id=123&lang=fr
MonLand
1995 D90 NAS
1996 Discovery NAS
Old March 25th, 2011, 07:14 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Nice setup for an extra tank. It says diesel, wonder if there is any problem using petrol in there. And will this fit on a 90?
Old March 25th, 2011, 07:33 PM
ron's Avatar
ron
Ron
tim give a call
781640 264zero
Old March 25th, 2011, 10:37 PM
MonLand
Loic Fabro
They say all their tanks are stainless steel. Now, I could not see that setup on their web site. Must be new! Also since there is like 90% of diesel there, it's possible they did not even check the gasoline setup. Anyway, I thought it was good to have other ideas/options.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old June 17th, 2011, 01:37 AM
RoverC
Cliff
1997 D90 ST
I actually have one of the 9 gal types that sits even with the frame and all the parts and templates that go with it. I had asked SR if they wanted to reproduce it and they never got back to me.
So if anyone knows a fabricator that can duplicate this in heavy duty alum let me know. I did get a quote locally from a welder for $600 to make it, but that wouldnt include the pump or filler neck etc.
The issue with the one I have is that it is steel and rusts, so a thick alum or alloy would be better.
Anyone interested in fabbing these PM me and we can discuss a deal.
fuel, fuel tank
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
How much work to drop the fuel tank? BarryO Defender Technical Discussions 5 July 15th, 2004 06:06 PM
