Automatic brake pedal or box - Defender Source
Old September 2nd, 2008, 09:22 AM
btate
Bryan Tate
d90
Looking for a brake pedal for an automatic (switched to auto tranny)
Would be glad to send you my manual style if that helped
If anyone has one around
Old September 3rd, 2008, 10:04 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Or do what we do and weld the wider foot onto your existing brake pedal box. No need to change to an entirely new pedal box.
Email:
Old September 3rd, 2008, 11:58 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I'll send you a correct size pedal with your radiator when it finally ships if you want!
legend in my own mind
Old September 3rd, 2008, 12:06 PM
btate
Bryan Tate
d90
Thanks guys,
Pendy I will call shortly about it....
I thought about welding one on, wasn't sure if the alignment in relation to the throttle was different.
That's plan number 2......
brake
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Looking for Automatic Brake pedal & Shifter plug. PCRover Wanted 2 May 8th, 2008 10:47 PM
brake pedal mattdh Defender Technical Discussions 1 February 12th, 2005 05:35 PM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
