Anybody know where I can find one of those cool fuel door covers.? - Defender Source
Old February 8th, 2012, 09:02 AM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
For a defender.... Couldn't find any pics online. Have seen em on d90s and 110s.
Old February 8th, 2012, 09:21 AM
I'm not sure why I'm telling you this as I am still upset I didn't check the site last night and snag your anti-sway bars but...
http://defendoor.co.uk/
Originally Posted by pendy
I'm here for the D's
Old February 8th, 2012, 10:34 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Bill at GBR has them or at least had them
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old February 8th, 2012, 03:48 PM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
Thanks guys! Sorry about that Charles, parts went fast. Still got the drive shaft and control arms
Old February 8th, 2012, 04:13 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
You need swaybars i think I have some used takeoffs in my personal stash. I can check next week when I'm back in the office.
Eric
Eric Riston
Old February 8th, 2012, 04:16 PM
Eric that would be great thanks - let me know what you have. I'd like to try setup a quick disconnect system for them so my truck is safer on road (my teenage daughter will be driving soon) but not have them off road (which I think Matt's had).
Old February 8th, 2012, 06:00 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I have a Defendoor. It's one of the those accessories you think is dumb and will never own one - until the day you can't open your fuel cap because the key hole is packed with mud. Been there....
Semper Fi!
Old February 8th, 2012, 06:08 PM
Get one direct from defendoor.co.uk like someone else pointed out...Mark Shelley is a good guy (ex-pat), he ships from overseas but it lands at your door in no time. His speaker boxes are also pretty cool.
My advice - order 2 for the time you leave it sitting at a gas station somewhere and forget to put it back on.
Old February 9th, 2012, 12:07 AM
CDeWan
Clay DeWan
5.3L beastie
Charles,
In the same boat as you....just wanted a set of disconnects and swaybar mount spacers. Tom M. beat me to the swaybar goodies. My current GBR axle rubs on my swaybar upon articulation as I have a 2 inch lift. I want the swaybar on road and to disconnect it off road.
Old February 9th, 2012, 08:36 AM
Clay, I'll let you know what I come up with. Someone said JK quick disconnects can be used (or modified to be used).
Old February 9th, 2012, 08:42 AM
I have the connectors on my truck, but not the sway bars. Can they be used with the stock sway bars?
Old February 9th, 2012, 11:39 AM
What connectors do you mean? Are you saying you have the little dog bone pieces are still on your truck but not the sway bars themselves?
And to keep this thread remotely on topic (sorry for the hijack), My solution to not getting mud in the gas cap key hole, or losing expensive defendendoors is to have a non-locking gas cap. I'll never have a problem opening it and as long as I don't lose it I'm all set. I have left mine at a gas station before (sadly more than once) but they are available cheaply at most auto pasts stores.
I realize in certain situations a locking gas cap can be desirable, but we are not traveling through Africa or South America.
Old February 9th, 2012, 11:42 AM
Or NE DC!
Old February 9th, 2012, 03:30 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Is this what you are looking at?:
http://store.jksmfg.com/merchant2/me...ar_Disconnects
Old February 9th, 2012, 05:31 PM
Yes. I haven't looked closely at the sway bar setup to tell if it would work, nor taken measurements, but thats the concept.
Old February 10th, 2012, 10:02 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Charles I have a super simple sway bar disconnect plan that a friend makes. You weld so all you need is a couple hours and bingo done. I will check for the bars early next week and let you know.
Eric
Eric Riston
Old February 10th, 2012, 10:39 AM
I've added a teatherd DII gas cap. rivnut in fuel well to secure teather with bolt. perfect fit. Added that after losing my cap on way to URE couple years ago.
Old February 10th, 2012, 04:49 PM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
Great idea !!!! Off to look for one.........
body, cover, door, fuel
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
97 D-90 SW blowing fuel pump fuses intermittantly BarryO Defender Technical Discussions 9 July 20th, 2004 03:07 PM
Fuel Thermistor Doug Defender Technical Discussions 4 February 5th, 2004 10:11 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
