Alternator swivel bracket - Defender Source
Old February 2nd, 2013, 01:38 AM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
I'm looking for this metal bracket, but with all the pieces.
Old February 2nd, 2013, 08:11 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Hit up one of the pull it yourself junkyards in SoCal near you.
Semper Fi!
Old February 2nd, 2013, 10:54 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Yeah, either pick-your-part or ecology down off the 905 should have a classic or disco down there.
If you get desperate, just go to the dealer and tell them you have a '94 Range Rover Classic, and you need the alternator link adjuster and they can get the part that way.
Old February 2nd, 2013, 12:11 PM
Surf90's Avatar
Surf90
C.S.
Good call on the junk yards. I called the LR dealership here and they had no idea what I was talking about. I gave them the part number then sent them the photo and they acted like I was looking for the most obscure part ever ... Junk yard it is.
Old February 2nd, 2013, 12:58 PM
pendy's Avatar
pendy
jim pendleton
89'd90
You are only missing one bolt. It is a bolt longer then the gap between the brackets. I has threads its entire length. It is used to set belt tension only and is not that important. If you really want one I am sure to have plenty of spares. What do you offer? I want something interesting to trade for.
legend in my own mind
Old February 2nd, 2013, 01:06 PM
Surf90's Avatar
Surf90
C.S.
Yeah the problem isn't the missing bolt it's one of the welded on bolts that I accidentally snapped off when loosening (should have greased them up) ... For trade ... Huh ... I've got a a box of hella lights I'm never going to use or a women's land rover watch (needs a new battery) I found in the glove box when I bought my truck ...
Or a rear passenger mud flap
Old February 2nd, 2013, 01:17 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I want the box of Hella lights and the women's watch. But I do not want to be greedy. What else could you use? Or do you want a credit with me. My parts collection is the most extensive known to mankind, well it is large anyway. PM me an address and I will get one headed your way. And I will get you my address to send the lights and watch on to.
Jim
Attachment 65577
Attachment 65578
Old February 2nd, 2013, 01:31 PM
azarmadillo's Avatar
azarmadillo
Chad Manz
1991 Range Rover Hunter
I have that alternator bracket. Call me. 480-363-2648.
ac, alternator, bracket, rack
upper Pan Hard rod bracket TDI Guy Wanted 10 April 17th, 2006 06:27 PM
Seatbelt bracket Chaucer Wanted 0 April 16th, 2005 08:53 PM
alt. bracket, door top hardware Abrooks Wanted 0 November 20th, 2004 06:23 PM
Seat Bracket dimensions, anyone? bd90 Defender Technical Discussions 1 August 26th, 2004 08:12 AM
Optima and standard D90 bracket artm Defender Technical Discussions 10 January 13th, 2004 04:24 PM
