Alternator - Defender Source
Old July 11th, 2005, 09:02 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Alternator
Anyone have one new/rebuilt for a 94 3.9. Also need plug wires if anyone has them.
Rich
Old July 11th, 2005, 10:50 PM
Plug wires can be had at the dealer cheap (I will get the PN tomorrow, it is an LRNA number) or for $65 from roverconnection you can get magnecor wires.
Old July 12th, 2005, 07:37 AM
Campbell's Avatar
Campbell
Rich Campbell
Thanks Ron,
I'm getting a strange noise when I start up cold coming from the area of the alternator. It goes away for the most part after it heats up. My battery indicator light was flicering from time to time. I check the batt and alternator output and the both check out fine. Any ideas?
Old July 12th, 2005, 07:57 AM
Remove the belt and spinn the alt by hand when it's cold. Maybe the bearings inside are worn and there could be a bad diode, it may be cheaper just to have it rebuilt.
Old July 12th, 2005, 09:15 PM
LRNA189712 is the wires part number.
I would just replace the alternator with a new one. It is more money, but I have had bad luck with rebuilds. Battery light I believe is only for low voltage so it can't be much other than the alternator. Around 100k or so is about right for needing a new one. The green D90 just got one at ~105k.
Old July 13th, 2005, 07:24 AM
Campbell's Avatar
Campbell
Rich Campbell
Thanks Ron. How is your 90 coming along?
Old July 13th, 2005, 11:54 PM
Its good. I think I am down to needing some AC work and a O2 sensor.
Old July 14th, 2005, 08:55 AM
Campbell's Avatar
Campbell
Rich Campbell
Cool....we should met up sometime so I can see your new 90. The hardtop sounds awesome.
alternator
MG Alternator and Starter Qs Hollywood Defender Technical Discussions 2 April 17th, 2005 06:31 AM
Alternator wiring tmore Defender Technical Discussions 5 April 11th, 2005 06:17 PM
Help With Alternator for a 97 UpnOver Defender Technical Discussions 5 March 20th, 2005 09:43 PM
Alternator Abrooks Defender Technical Discussions 8 March 15th, 2005 10:59 AM
Dual Batts and HO Alternator jamesriding Defender Technical Discussions 42 January 9th, 2005 04:27 PM
