Alternator - Defender Source
Old January 11th, 2005, 10:51 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
Alternator
Help! I need an alternator. It's a long story (see Avatar - that sums up my Disco) .. 100 amp Magnet Marelli 12V please. Used, Off a wrecked truck, @ this point I just need it. THX! PM Please.
I bought the diamonds myself so I would not have to say thank you to anyone.
Old January 11th, 2005, 10:59 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
What year Disco1? There were 2 different alternators with different pulley sizes...or alternatively, what is the part number you are looking for? I have a rebuilt alternator for a 1994/1995, I have a rebuildable alternator (bad diode) for a 1996-1999...could have it done fairly quickly.
Rob
Old January 11th, 2005, 11:15 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
Hey Rob! THX! It is a 1998. Would your alt come with the pulley? Therefore the later of the two would work please. Do u paypal?
Old January 12th, 2005, 08:06 PM
Roadsiderob
Robert Dassler
1994 D90
Yes, it will have the pulley. I will take it to the rebuilder tomorrow. Yes, I have pay pal.
Rob
Old January 17th, 2005, 07:54 AM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
BTT
Hey Rob..How is this coming along? Can you PM me please and let me know if you still have it..I still need an alt. THX!
Old January 17th, 2005, 02:17 PM
Roadsiderob
Robert Dassler
1994 D90
The alternator is at the rebuilder...they dismantled it and ordered parts last week...should be finished today...am waiting for their call. I took the core in trade. I was told that it came off of a D1, however, I suspect it may actually have come off of a 1997 Range Rover as it is a 120Amp unit. It has the small 7 rib pulley and the mounting feet are the same as a D1, however, it has a larger 8mm output stud. It may necessitate crimping a bigger terminal end onto your charge wire. If you can fabricate a brake line, I expect this would not be much of a problem. The only thing I am not sure about is if the tach will be accurate. The Land Rovers tachometers use an A/C signal off of the alternator to drive the tachometer...am not sure how the signal will match up. I'll email as soon as I get the unit back. You can buy it and try it, and if it doesn't work out, I'll take it back.
Rob
Just got a call from the rebuilder...the front case broke when they tried to press the stator out.
Do you want to try to rebuild your alternator or use the case from it?
Rob
Old January 17th, 2005, 05:38 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
Thank you so much. I appreciate it.
I do not have an alternator as of now Rob. A friend locally needed the one (MM) that I had rebuilt so I gave it to him (on the side of the road action). I already returned the Bosch Remanufactured one, so the rover is without an alternator. No worries I can keep it parked for now. Another friend is building a GM alt conversion for me. I can wait. I hate to see this cause issues. Let me know your thoughts or you can email me. Thank you again.
Old January 17th, 2005, 07:04 PM
Roadsiderob
Robert Dassler
1994 D90
No worries!
Rob
alternator
MG Alternator and Starter Qs Hollywood Defender Technical Discussions 2 April 17th, 2005 06:31 AM
Alternator wiring tmore Defender Technical Discussions 5 April 11th, 2005 06:17 PM
Help With Alternator for a 97 UpnOver Defender Technical Discussions 5 March 20th, 2005 09:43 PM
Alternator Abrooks Defender Technical Discussions 8 March 15th, 2005 10:59 AM
Dual Batts and HO Alternator jamesriding Defender Technical Discussions 42 January 9th, 2005 04:27 PM
