Accelerator cable piece - Defender Source
Old September 9th, 2013, 12:00 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Hi,
The plastic "thing" that is used to adjust the tension of the cable to the throttle body died on me. Everything else with my accelerator cable is fine. Since the cable assembly runs in the $50 (I think, looked at NTC9163 on Google briefly) I figured trying to find that plastic piece might be worth a shot. Was able to keep wheeling it with a bunch of zip ties, but the setup is not safe (try to have your engine rev up to 2500 rpm when trying to go up a tight obstacle.... ).
Anyone with a broken accelerator cable assembly that is trying to unload it? I "only" need the plastic piece that threads onto the cable.
Loic.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 9th, 2013, 12:11 PM
I wired mine on the RRC. Couple X wraps of copper wire around the plastic jimmy and the cable stop bracket and dunny dun. If I ever need to adjust it, I just loosen the wire.
Old September 9th, 2013, 12:32 PM
MonLand
Loic Fabro
Hum... I guess copper wires are stiffer and might work. The zip ties kept on sliding and it took patience and a lot of trials to get something that was "stable"!
MonLand
1995 D90 NAS
1996 Discovery NAS
ac
little plastic thin piece that is glued down to cover the light near the heat switch d90guyinla Wanted 10 February 5th, 2013 05:01 PM
last piece for sale: 4 mastercraft harnesses NASD90 For Sale - Parts 3 December 9th, 2005 06:53 AM
Part # Question - Trim Piece fleabus Defender Technical Discussions 6 July 5th, 2005 02:45 PM
one piece hard top? ONDROX Defender Technical Discussions 4 November 22nd, 2004 08:21 AM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
