AC pulley tensioner - Defender Source
Old September 8th, 2008, 11:23 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
AC pulley tensioner
I ordered the wrong pulley from AB. I need the pulley that fit a 94 with AC.
I bought this one: http://www.roverparts.com/Parts/ETC6159.cfm
And I need one that look like this by Friday!
ID:	15175   Click image for larger version
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 9th, 2008, 10:42 AM
dsticht
David Sticht
'94 AA D90 ST
A/C pulley
Dan... mine went out in Moab a few years ago. I took off the same as in your pix and went to NAPA. They had one very close. As I somewhat recall, the collered bolt would not fit. I went to the hardware store and found a normal bolt the proper thread and length. The bolt was a slightly sloppy fit, but the head would tighten down on the bearing and not the rotating pully. Installed and fine now for 3 years. Part...Drive Allign-90mm-#38003
Dave
Old September 9th, 2008, 11:32 AM
ini88's Avatar
ini88
Daniel Marcello
Dave
Great! So NAPA has a pulley just like this one you are saying? And then all i need is a new bolt to secure the pulley onto the arm right? Do you remember the part number from NAPA?
is this the part?
http://www.rockauto.com/catalog/cata...BGATES%2B38003
or this right?
http://www.autopartswarehouse.com/de...QGAT38003.html
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 9th, 2008, 11:50 AM
dsticht
David Sticht
'94 AA D90 ST
Dan... the part number is in my post. It has a sticker on the box that sez-----NAPA, belts hose, 38003. Then on end of box---DriveAlign-groove idler pulley-90mm. As I said it is not an exact replacement because the bolt hole is a different size. The bolt I used would wobble in the hole but the pulley will tighten solid when the head of the bolt tightens .I think you will see what I mean when you get the new bolt
Dave
Old September 9th, 2008, 11:53 AM
ini88's Avatar
ini88
Daniel Marcello
Yeah I called NAPA and they have one in stock. Thanks so much. I have to drive 4500 miles on it in the next 2 weeks so I thank you!
Do you remember the bolt size too? No worries if you don't
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 9th, 2008, 12:08 PM
dsticht
David Sticht
'94 AA D90 ST
Dan... the picture of first one looks like it
Are you going to Moab?
Old September 9th, 2008, 12:11 PM
ini88's Avatar
ini88
Daniel Marcello
oh i get you now. sorry im spacing out at work trying to get stuff done. So i can reuse the same bolt then. cool.
Yeah I will be going to the National Rally. Driving out Saturday. You going?
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 9th, 2008, 12:26 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
If NAPA doesn't work I have a used one. Don't know how many miles are on it, came from a 90 that we updated the AC on.
Email:
Old September 9th, 2008, 12:33 PM
dsticht
David Sticht
'94 AA D90 ST
no, a different bolt
Old September 9th, 2008, 06:35 PM
ini88's Avatar
ini88
Daniel Marcello
I will know tomorrow morning if the NAPA pulley doesn't work. If not, I will give you a call and see if I can get that to NY asap.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 18th, 2010, 09:26 AM
ini88's Avatar
ini88
Daniel Marcello
old bump! Does anyone have one of these for sale? I did some reseach and think I found out that the bearing is a 40mm/17mm/12mm.
Old November 18th, 2010, 09:33 AM
Bearing or pully? I have a used one I could send you.
Old November 18th, 2010, 09:34 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Dan,
I might have one of these at home. I will check tonight.
Greg
Old November 18th, 2010, 11:50 AM
ini88's Avatar
ini88
Daniel Marcello
Bearing and or pulley. I think I have the pulley someone but might have gotten rid of it because the bearing seize/melted to the pulley. I can't remember. I have a pulley in place but it on it's way out because it is slight off size.
Anything will help! Thanks.
Old November 18th, 2010, 12:02 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Daniel, I am sure i have one, will look tonight
3rd low and BOOT IT
Old November 18th, 2010, 12:22 PM
ini88's Avatar
ini88
Daniel Marcello
Thanks guys!
Old November 18th, 2010, 01:16 PM
Ok, I'm leaving for vacation tomorrow so best one of these guys send one. If you still need one in a week or so let me know.
Old November 18th, 2010, 01:35 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Damn, I just had one of these - and I thought Buckhorn had it, but had to edit out the URL
-Ren Ching
Old November 18th, 2010, 01:36 PM
He needs v-belt style
Old November 18th, 2010, 02:32 PM
ini88's Avatar
ini88
Daniel Marcello
Yup V-belt style for the A/C pulley. not the idler pulley way down.
Charles, I none of these guys have it then i will hit you up after vacation. I'm not in a rush, and its still drivable and yes... its only the A/C so no worries.
ac, pulley
Need Crank Pulley RedRhinoProducts Wanted 0 November 16th, 2005 11:41 AM
Water pump tensioner Mike Hippert Defender Technical Discussions 22 March 27th, 2005 12:16 AM
AC Pulley, Tension Mike Hippert Wanted 4 July 29th, 2004 12:04 PM
Replacing pulley bearing Campbell Defender Technical Discussions 4 April 26th, 2004 08:42 AM
Need A/C tensioner pulley Campbell Wanted 0 April 24th, 2004 10:19 AM
