AC Condensor Fan Brackets - Defender Source
Old July 16th, 2010, 05:56 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Need the two top and two bottom brackets that hold the condensor fan in place in front of the radiator.
Alex
Old July 17th, 2010, 10:42 AM
dogbite's Avatar
dogbite
Paul D
95 D90 ST & SW
Is this what your after? You can have them but it looks like i'm missing one of the zip ties.....
Just let me know.
ID:	29427   Click image for larger version
Old July 17th, 2010, 10:55 AM
aosias's Avatar
aosias
Alexandra
1995 D90
I need the metal brackets that attach to the condenser, not the actual fan. There are 4 brackets that attach to each corner.
Old July 17th, 2010, 11:14 AM
dogbite's Avatar
dogbite
Paul D
95 D90 ST & SW
oh...got ya... these are what you need then? lower brackets are skrew on and in fine condition... the upper ones got pert hot are riveted on and not in the best condition. you could make the top ones fairly easily.
Old July 17th, 2010, 12:41 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Yes! Will you PM me your number?
ac, bracket, fan, rack
Rear Seat Belt Brackets zed111 Defender Technical Discussions 11 August 6th, 2007 02:45 PM
Rear A-Arm Frame Brackets..etc TDI Guy Wanted 14 February 16th, 2006 09:15 AM
rear bench brackets jts Defender Technical Discussions 1 November 20th, 2005 09:42 PM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Wanted 2 August 16th, 2004 12:33 PM
» Defender Registry
Hank
D110
"Lucy"
PavementEnds
Add your Defender
