AC Condensor Fan ('97 Defender) - Defender Source
Old August 31st, 2009, 08:33 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I need a fan in very good condition (i.e., no water/mud crossings please). Or, if you know how to cross-ref these to another supplier that would be helpful too. I can't believe these are $350 from a LR supplier like AB or RN when they're $50 from an autoparts store.
Clay
Old August 31st, 2009, 10:31 AM
Why not use a ProComp, Flex-i-lite or another aftermarket fan? You can get them cheap and in just about any size.
Old August 31st, 2009, 10:59 AM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
Clay
I have 2 off my 96 disco if your interested... they worked fine when removed
100 beans and they are both yours...
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old August 31st, 2009, 02:58 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
The original off the 97 I am rebuilding is a SPAL unit, I couldnt find an exact replacement but they do have one that will fit in exactly the same manner and in the same space PN#30102040. Ordered online for a reasonable price, but I forget the site or the exact price.
Old August 31st, 2009, 04:14 PM
1of40's Avatar
1of40
1of40
Joel, thanks for the tip. i took a look and the PN shows a 4 blade fan. Is that what you went with? My OEM has maybe 10 curved blades so I'm just wondering.
Old September 2nd, 2009, 09:34 AM
crown14's Avatar
crown14
Verticalscrote
The one I have is a 5 blade fan, I did quite a bit of researching on it and if anything the 5 blade I picked is a little higher output than the one from the dealer-installed AC kit. As you can see it is not physically identical but the original mounts to some brackets and the brackets mount to the condenser. The new fan will mount in the same location that the old brackets did, so direct fit other than swapping the old harness plug onto it.
ID:	21327   Click image for larger version
97, ac, fan
1997 NAS Defender 90 AC kits ECR The Vendors Loft 2 December 22nd, 2009 07:18 PM
AC Fan 97 Defender 1of40 Wanted 2 May 12th, 2009 04:04 PM
WTB 97 NAS D90 AC system ECR Wanted 7 July 16th, 2008 07:58 AM
97 Defender ECU nardo Defender Technical Discussions 0 November 26th, 2003 04:36 PM
Wanted 97 Defender Gray Jump Seats rbtrader Wanted 1 October 10th, 2003 10:29 PM
