Abs Ecu - Defender Source
Old April 4th, 2006, 02:49 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Abs Ecu
Took the D-90 into the local mechanic and had the ABS sensor replaced last week b/c of a check engine light. Check Engine came back on and we can't get the ECU to clear the code even though all the sensors are good. So I'm looking for a replacement ECU - part Number ANR 5508 out of a 97 Defender. Anyone got one colelcting dust?
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old April 13th, 2006, 03:04 PM
Cholla
Jack Copass
97 D-90 SW
Persistent ABS Fault
I had the same problem, repeated fault P1317. Dealer diagnosed faulty RR ABS wheel speed sensor. After replacing the rear sensors (2 with the loom), still the same fault code. Then replaced the 2 rear sensor wiring 2-pin plugs. Same problem persisted, finally, I pulled out front wheel ABS sensors, cleaned, relubed- no further problem for 5 months now. This ABS sensor set-up on the 97 can be a pain, but if yours is that computer, it really doesn't cause any malfunction--just the check engine light stays on... Hope this helps, Jack
ecu
97 D90 ABS ECU and short harness pendy For Sale - Parts 1 April 15th, 2010 11:33 PM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Interface on '94 ECU (OBD-I?) jaherring Defender Technical Discussions 10 October 11th, 2005 10:06 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
