A/C Blower Needed for 1995 D90 - Defender Source
Old May 5th, 2012, 01:05 PM
Overland90's Avatar
Overland90
95/D90 #169; Aston Martin
All...In need of this Air Conditioning blower. Any help identifying which one this is?
I believe it's a Wynn but no markings...no where!
No parts number either...?
Thanks for any help identifying and locating replacement.
Old August 23rd, 2014, 05:57 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Did you find a replacement ?
I think mine is dead also.
Cheers
- Charles Eames
Old August 23rd, 2014, 10:33 PM
Have you guys had any local electric motor shops take a look at them? You could probably have them rebuilt.
Old August 23rd, 2014, 11:55 PM
madcowdungbeetle
Carter
I believe i have one.
Old August 24th, 2014, 12:16 AM
2411D90's Avatar
2411D90
Bob Vogler
1995 D90 Fastback ST (Beluga Black)
You might check this thread that I came across when my blower burned out:
http://www.defendersource.com/forum/...highlight=wynn
Bob Vogler
Recovering Economist
Old August 24th, 2014, 10:19 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
That is going to be my first move.
I may also swap the steel balls on each shaft
side by bronze ones.
Cheers
- Charles Eames
Old August 24th, 2014, 10:23 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Originally Posted by JFD View Post
That is going to be my first move. I may also swap the steel balls on each shaft side by bronze ones. Cheers
With my 93 blower motor (different from 94/95/97) it couldn't be rebuilt because there is no way to open and reseal. If there isn't blatant bolts and nuts enabling you to open then it's not able to be rebuilt.
Old August 24th, 2014, 10:52 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
It is sealed, no bolts and nuts, each end is pressed in, but you can grind
a little bit the lock to have it open. When you close it two very small weld
spot on each ear and you're done.
Third world systems :-))
- Charles Eames
Old August 24th, 2014, 10:59 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
It is sealed, no bolts and nuts, each end is pressed in, but you can grind a little bit the lock to have it open. When you close it two very small weld spot on each ear and you're done. Third world systems :-))
Understand but the three places that saw mine wouldn't even attempt to open and Reseal - maybe to them not worth the effort.
Old August 24th, 2014, 11:20 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Probably. You can open it yourself, brushes assembly is easy to remove (2 small springs), open only one side (the one without the carbon brushes) then you can take out the core. You may have to sand clean the shafts in order to remove both steel balls.
I have a few broken wires on mine.
Cheers
- Charles Eames
Old August 24th, 2014, 12:14 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I have used a universal replacement blower motor in the 1995 D90. Try This: https://omega-usa.com/AC-Part/26-14612.html
Napa offers about 50 different universal blower motors. You can always pull yours and match it up.
I also have a relatively complete HVAC system for a NAS110 here at the shop including the blower motor if anyone needs it.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old August 24th, 2014, 03:44 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
That may work.
- Charles Eames
Old August 24th, 2014, 04:33 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
Anybody have info for a 94 Davia system blower motor replacement?
Old August 25th, 2014, 01:09 PM
Overland90's Avatar
Overland90
Cheers
Yes...found it here...however, that one is also not long for the world. Squealing like a stuck pig, often stopping. mid-blow, with the aroma of burning plastic emanating from its "cage". I chalk it up to "typical Land Rover" feces and will be seeking a replacement soon.
Defender ownership is a true "love hate".
If you have not already torn apart your system...you can simply use a "stubby" phillips head screwdriver and wedge your hands underneath the A/C in the passenger footwell unit and identify the 6/8 screws to release the blower unit and determine what you need.
For all the trouble, I would suggest just buying the new one listed by Roadsiderob https://omega-usa.com/AC-Part/26-14612.html and rig it to work for you...just saying...
Old August 25th, 2014, 08:05 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I took my all A/C out, pull out the evaporator to clean it (resealing leakproof the box is always a pita), i'm making new copper bushings for the motor and rewiring the rotor, also a new speed selector resistance. I hope that will give me a couple of years of cold and quiet.
Cheers
- Charles Eames
1995, 90, 95, 95 defender a/c blower, d90
Needed: Winch, Bush Bar, Soft & Hard Tops etc for D90 Erimus 1 Wanted 9 March 1st, 2007 10:54 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
FOR SALE: 97 D90 S/W with A/C 66k miles MEvans For Sale - Vehicles 0 January 30th, 2005 05:02 PM
95 D90 for Sale 130K A/C manual bconab For Sale - Vehicles 4 July 30th, 2004 11:27 PM
