97 D90 Radiator cowl/shroud - Defender Source
Old June 20th, 2011, 08:09 PM
Verner Berry's Avatar
Verner Berry
Verner Berry
97 D90
Looking for the lower radiator cowl/shroud for the 4.0
Thanks, VB
Old June 20th, 2011, 08:53 PM
CDeWan
Clay DeWan
5.3L beastie
shroud
maybe a dumb question but is the 97 different that the 94 and 95 due to the auto tranny lines?
Old June 21st, 2011, 08:49 PM
Verner Berry
Verner Berry
97 D90
Unfortunately I'm being told that they are different and will not work, thanks though
Old June 23rd, 2011, 09:28 PM
Verner Berry
Verner Berry
97 D90
Bump??
Anybody??
I beginning to think finding Waldo would be easier.
Old June 23rd, 2011, 10:30 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
I think we spoke yesterday... Did Stephen not have one?
Might also try to email ECR. Mike usually responds pretty quick early in the mornings. info at eastcoastrover dot com
might also try pendy pendy at pixius dot com
I guess you've tried Rovers North?
You'll probably have to buy the whole thing. You would be very lucky to find someone with just the lower half lying around.
------ Follow up post added June 23rd, 2011 09:34 PM ------
http://www.roversnorth.com/store/p-3...fender-90.aspx
Also part number ERR7307
Old June 24th, 2011, 08:06 PM
Verner Berry
Verner Berry
97 D90
Yep, no luck with Safari Rover, everyone I talk to is back ordered. I will give ECR a try, thanks for the help.
VB
Old June 24th, 2011, 08:40 PM
specops1526's Avatar
specops1526
Beluga '97 90
There was one for sale here a little while back. I've been PMing with the seller regarding another item he had for sale but haven't received a response back in a while...
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old July 1st, 2011, 12:29 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I was able to get one at British Parts International (BPI) here in Houston with no problem.
Might want to check with them.
Nick
Old July 1st, 2011, 03:12 PM
How much was it?
Old July 5th, 2011, 03:36 PM
97-D90-736
Nick Vogel
Scott; I think it was a hundred and change...
Old July 5th, 2011, 03:55 PM
Thanks Nick!
Old July 5th, 2011, 08:55 PM
Verner Berry
Verner Berry
97 D90
Nick
Nick, Thanks for the input I'll check it out.
Old August 7th, 2011, 01:45 PM
Verner Berry
Verner Berry
97 D90
Still in desperate need of the lower fan shroud for 97 D90, if anyone knows of any leads it would be greatly appreciated.
Thanks, VB
Old August 7th, 2011, 02:10 PM
specops1526
Beluga '97 90
Have you searched ebay for DI shrouds? I'm pretty sure they are the same and they are usually cheap on ebay.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old August 7th, 2011, 02:48 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
Hi, Gents-
I also need one, and I can confirm that the D1 lower shrouds are not the same as the 97 D90. (I bought a upper/lower D1 set on Ebay hoping that both would work, but only the upper part is the same as the D90.)
I've had the correct one on backorder from RN for about 10 weeks, and may just end up trying to buy one from the UK directly when I get home from deployment. The 97 NAS D90 uses the same one as the 98 UK 50th Anniversary model (which also had a 4.0L V8).
The part # you need is ERR7307. Let me know if you find more than one!
When I do the 4.6 swap in my 94 in the spring, I'll probably have to fab something or figure out a way to modify the D1 one I have if I'm not able to find the correct one. I'm guessing that a swap is what has you looking.
Good luck!
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old August 7th, 2011, 02:50 PM
specops1526
Beluga '97 90
Ah, good to know about the lower part. I knew the upper was definitely the same.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old August 7th, 2011, 02:57 PM
Verner Berry
Verner Berry
97 D90
I also tried to modify the D1 shroud with a dremel tool and ended up with a piece of shredded plastic and a burnt up dremel tool.
Old August 8th, 2011, 10:57 AM
I'm curious to know what the differences are. I have used a D1 shroud on D90's, both auto and manual, and it was simply a matter of trimming the corners to get it to fit. As others have said they are cheap and available.
Originally Posted by pendy
I'm here for the D's
Old August 8th, 2011, 07:43 PM
Verner Berry
Verner Berry
97 D90
I guess my skills are not up to par. I trimmed the sides but the bottom hits the fan and w my dremel tool is toast.
Old August 9th, 2011, 08:10 AM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
Use an air cut off wheel to mod a defender one. I've had to do it but I hate it. I have 20 on order and nothing. Been at least 6 months.
90, 97, 97 d90, d90, radiator
headers for '97 D90 mdmccallum Defender Technical Discussions 43 April 25th, 2005 10:23 AM
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
OEM MAF sensor from '97 D90.... dmarchand For Sale - Parts 4 June 18th, 2004 06:49 AM
97 D90 maxing out at ~70mph?? vnrover Defender Technical Discussions 3 November 10th, 2003 02:14 PM
For Sale: '97 D90 ST-1791 Alpine White jwebster For Sale - Vehicles 0 September 30th, 2003 12:36 AM
