95 4.2 front timing cover & oil pump cover - Defender Source
Old August 14th, 2015, 01:39 PM
psykokid
Jake
1997 Disco
I've got a friend in the bay area that has been chasing all sorts of problems with his 4.2 swapped disco. It looks like his front timing cover and oil pump cover are worn beyond tolerances and he's getting low oil pressure and some random oil leaks. If anyone has a front timing cover and the oil pump cover for a serpentine belt driven / distributor 4.2 from a 95 RRC kicking around in good shape please let me know.
Old August 14th, 2015, 03:06 PM
psykokid
Jake
1997 Disco
Thinking about it a cover from a 95 disco should suit as well, just to broaden things up a bit..
Old August 14th, 2015, 03:59 PM
SLO Hybrid's Avatar
SLO Hybrid
Nathan Harrison
95 25th RRC/94 LWB /04 L322/87 RRC
Or any 95 V8 w/Distributor Rover
Old August 14th, 2015, 04:04 PM
Not a 95 defender though.
Old August 14th, 2015, 06:16 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
We have used ones with new gears etc.
2450 North Forsyth Rd
Winter Park, FL
(407)517-4983
95, cover
Removing Front Timing Cover '97 D90 BMGmotors Defender Technical Discussions 9 May 21st, 2014 06:56 AM
300tdi Front engine/timing cover trybul Wanted 2 August 3rd, 2011 09:28 AM
Looking for oil pump / front cover & crankshaft pulley HeloBubba Wanted 1 February 12th, 2011 02:20 PM
front cover, crank driven oil pump with distributor Davis Defender Technical Discussions 11 March 20th, 2010 12:52 PM
Need to change front timing cover seals, auto trans flush... NY/NJ/MA/VT/CT area? KKilo23 Defender Technical Discussions 4 September 21st, 2009 03:35 PM
