94 D90 upper speedo cable PRC9555 - Defender Source
Old September 4th, 2012, 05:11 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I've come up with p/n PRC9555, but can't find one. I'll even settle for a functioning used one if that's all ther eis.
Whatcha got?
Email is
Same place, new dogs.
Old September 4th, 2012, 05:37 PM
do you have a non functioning one? I repaired mine using a $5 cable from autozone
Old September 4th, 2012, 05:44 PM
Roverlab
Trevor Griffiths
Broken connector at back of speedo, broken inner cable, melted outercable from LH manifold. Yup, kinda fubar.
Email is
Old September 4th, 2012, 05:55 PM
change to a VDO ... it's about the same cost at the end of the day
Old September 4th, 2012, 08:24 PM
nwp's Avatar
nwp
Nathan Patterson
1994 D-90
I changed out all of mine to VDO Vision series. I put LED lights in them as well. There are threads that outline the process pretty clearly.
ID:	57084   Click image for larger version
Old September 5th, 2012, 06:54 AM
Roverlab
Trevor Griffiths
The VDO was one of the options; just wanted to see if I could resolve the issue with a Genuine part.
Email is
Old September 5th, 2012, 04:25 PM
CDeWan
Clay DeWan
5.3L beastie
speedo
Trevor,
There is a local shop here that will make you one - Foreign Speedo and Tach (san diego). You may just want to try a local guage repair place.
Clay
Old September 7th, 2012, 08:43 PM
I'm told there is a programmable vdo that you can set yourself. Anyone know which one that is?
Old September 8th, 2012, 09:52 AM
there is a big VDO gauge thread that has all the answers
90, 95, d90, speedo
Upper speedo cable PRC9555 cgalpin Wanted 11 October 5th, 2012 12:11 AM
speedo for 97 D90 ome mjekogian Wanted 2 February 14th, 2006 12:53 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
Needed: Hood Release Cable NAS D90 Hans Wanted 4 August 6th, 2005 03:18 PM
NEW speedo cable mpodgorski For Sale - Parts 5 July 22nd, 2004 10:46 AM
