'93 NAS D110 AC Condenser Fan - Defender Source
Old July 12th, 2009, 09:25 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
I need two condenser fan motors for my NAS D110.
part #RTC7424
it is the electric motor for the the small fans that sit just in front of the radiator found only on the '93 D110s
used and tested working ok too...
I may just fit one large oem type electric switch fan that I can switch on manually for those hot days (open for ideas). I would like to keep it original, but there may be a better option.
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old July 12th, 2009, 10:01 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Its a US made part, OEM. Can't recall right now, but it is a Perma-Cool or something. No need to get the LR unit as it is just in a different box. They are readily available.
Email:
Old July 12th, 2009, 10:17 AM
Jon_Winningham
Sterling M Archer
That is the one, thanks!!! (again)
Perma-Cool 19010 - Perma-Cool High Performance Electric Fans
Old July 12th, 2009, 11:03 AM
bjf's Avatar
bjf
barry f
94 ST #395
What do these do?
Old July 12th, 2009, 10:09 PM
I have two that look really nice. Say $100 plus $20 to get them to you?
Old July 17th, 2009, 06:57 PM
Jon_Winningham
Sterling M Archer
Originally Posted by bjf
What do these do?
they cool the A/C coil that pulls the heat off the system, and I think they kick on to help cool the engine when it gets real hot
Old July 18th, 2009, 08:08 AM
Jon_Winningham
Sterling M Archer
Thanks Ron...
check is in the mail
Old July 18th, 2009, 05:22 PM
Ok,
PM me your address as to where to send them.
Ron
Old July 29th, 2009, 08:03 PM
Jon_Winningham
Sterling M Archer
Thanks Ron...
I got them installed today, and the work great.
Now my AC works even better, although this is one of the coolest July's in KC history...
Old July 30th, 2009, 09:31 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
FYI, they're the same fan as in the RRC. I picked a used one to replace the seized one in my NAS 110. Just make sure they're all spinning the right way once they're hooked up.
Chance
Old July 30th, 2009, 09:45 AM
Originally Posted by Jon_Winningham
Thanks Ron...
Glad you are happy.
Ron
Old July 30th, 2009, 10:33 AM
Jon_Winningham
Sterling M Archer
I had to reverse the wires so that both fans blow outside air towards the engine. I think that is correct...
Now the next NAS D110 guy with this problem will have all the answers! That is if they do a search on the topic first...
Old August 1st, 2009, 08:01 PM
bjf's Avatar
bjf
barry f
94 ST #395
are those permacool fans definitely the right ones? Direct replacements?
Old August 2nd, 2009, 12:16 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I have a half dozen of these if anyone else needs this type fan. I would never put one back together with this type arrangement. Its is not an efficient arrangement.
legend in my own mind
Old August 2nd, 2009, 12:27 PM
bjf's Avatar
bjf
barry f
94 ST #395
I need them PM sent.
Old August 2nd, 2009, 06:28 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Are you saying that if you have a NAS 110 with say a 4.6 that you would go a different way than these fans? If so, ... what would you do?
It is pretty evident by all the chatter and from my personal experience that this system does not work or cool very well anyway. We all know the air conditioner is a POS as well, so why they initially had these fans tied to the AC switch is a mystery to me. Luckily the PO put a manual switch in mine that allows me to switch the fans on based on engine temp. So, I am wondering what is a better route? Why do we not see this type of engine heat when a 3.9 or 4.6 is in a rangie? Why only a 90 or 110?
Thoughts?
Dendy
Old August 2nd, 2009, 06:39 PM
pendy's Avatar
pendy
jim pendleton
89'd90
D90 and D110 are bricks on the highway. Approach angle is a huge drag at fast highway speeds. Not an issue on trails and countryside meandering.
The A/C in a 93' is a POS. Evaporator in the engine bay is flat out a stupid design that just cycles from engine bay heat.
Get on Summit or Jegs and look at the CFM output of something that will fit. I like the BeCool fans. Something that sits right against the condensor.
You have to take time and seal off the radiator and condensor to keep from recycling engine bay heat as well.
Old August 2nd, 2009, 09:22 PM
bjf's Avatar
bjf
barry f
94 ST #395
I ended up ordering some new perma-cool fans since they were cheap figured no point going used. Anyone else order these? Wondering if the bolts are the same to hold them in.
Old December 12th, 2014, 12:32 PM
jmx
John Cross
1993/D110 NAS
1993 D110 AC Condensor Fan Motor
The Perma-Cool high performance fan, 19010, has been discontinued. They told me that the blade manufacturer had discontinued the 10". However, they do have the ac condenser fan motors - part no. 19220.
perms-cool.com, then go to their store and do the search. $81 per.
I've ordered one and will update.
Old January 17th, 2015, 11:49 AM
jmx
John Cross
1993/D110 NAS
The fan motor worked fine. And at the price, I'll happily replace it several more times should I be so fortunate.
110, ac, d110, fan, nas
just drove my first NAS D110 (282/500) norros Misc. Chit-Chat 18 February 11th, 2015 06:02 PM
converting NAS '93 D110 or '07 D110 cosmetic specs rrcowner Defender Technical Discussions 2 March 5th, 2009 07:20 PM
'93 NAS D110 Brake Light ON Lesandjes Defender Technical Discussions 5 June 21st, 2008 02:50 PM
Wanted 1993 NAS D110 Jon_Winningham Wanted 1 November 16th, 2006 10:20 AM
D110 Nas rvrsrvc For Sale - Vehicles 15 December 7th, 2005 02:17 PM
