4CU refurbished and - Defender Source
Old August 19th, 2013, 09:58 PM
molonlabedoc
Vincent
1987 D90
4CU refurbished and
a refurbished Lucas 5A Air flow meter. Anyone know anyone doing this? Or that sells them anymore?
My D90 has a 2002 Disco 4 in it, connected to a 4cu (not a 13 o4 14) connected to a Lucas 5A Air Flow Meter, and there is some stuttering at times at low RPMs.
The last owner assumed the low throttle response was from a smaller V8, only to find after an engine swap, it was no better.
Any thoughts?
Old August 19th, 2013, 11:41 PM
Find a LR test document and run though the test procedures. Google is generally your friend.
Old August 20th, 2013, 10:12 AM
molonlabedoc
Vincent
1987 D90
I misspoke on the Air flow meter, its a Lucas 2AM.
Old August 20th, 2013, 10:31 AM
Stumbling at low RPM is generally a problem with air idle control mechanisms ...
try reading this ... http://www.jcna.com/forums/view.php?...0&Vthread=6585
swapping out the Air flow meter on the basis of assumptions is an expensive way to troubleshoot a proble.
Old August 20th, 2013, 11:27 AM
molonlabedoc
Vincent
1987 D90
Thanks for the info, I will get on that.
1962 Land Rover Series IIa 88'' refurbished Mike Sandone For Sale - Vehicles 2 October 22nd, 2012 04:25 PM
4CU --> 14CUX conversion neduro Defender Technical Discussions 10 October 9th, 2012 05:06 PM
Refurbished Steering Boxes BMGmotors Defender Technical Discussions 2 August 10th, 2012 07:18 PM
Refurbished Series 3 LHD 109's globallandrovers The Vendors Loft 0 February 7th, 2009 07:41 PM
Refurbished 1984 LR90 Station Wagon globallandrovers The Vendors Loft 2 January 28th, 2009 04:28 AM
