4.6 crank and rods - Defender Source
Old December 5th, 2013, 10:05 PM
4.6 crank and rods
don't need the block or pistons just the crank and rods.
don't mind one that needs to be micro polished but not interested in burned or scored
Old December 6th, 2013, 08:15 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Doug, I will check with an old friend of mine that might have a set. In the meantime post or PM me if you locate one from another source.
Clay
Old December 6th, 2013, 10:00 AM
Clay
sounds good Clay. I have missed a few cheap slipped liner blocks on craigslist and figured I'd see who has what squirreled away here
Old December 8th, 2013, 12:46 PM
Roving Beetle
Doug
I have a whole block 4.6 bosch 2004 that has bad head bolt threads. Crank looks great. Pistons etc are great. No issues except the center upper threads are pulled out on both sides. If you're interested let me know.
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old December 8th, 2013, 12:50 PM
Doug-shoot me a pm as to what you want for it.
Old December 9th, 2013, 12:34 PM
1of40's Avatar
1of40
1of40
Doug C, sending you a PM.
Clay
Old December 10th, 2013, 11:27 PM
jafir's Avatar
jafir
Jafir Elkurd
http://www.defendersource.com/forum/...ad.php?t=50217
Old December 12th, 2013, 10:25 PM
crobinson
Chris Robinson
97' D1
I have a new take off GEMS 4.6 cam if your interested.
Old December 13th, 2013, 02:40 PM
ARP studs or overzealous mechanic?
Old December 13th, 2013, 04:17 PM
Roving Beetle
Doug
Well one side upper center bolt ALREADY had a half-assed hellicoil. Replaced with proper long insert and it felt odd at the initial 15 ish torque. Then pulled out about half way through the first 90 degree turn on new stock bolts, threads well chased, cleaned with brake clean and blown out/checked and then bolts lightly oiled etc.
The other side - same hole, upper center felt odd after the first 90 and on the second pass it immediately let go.
The block had been hot clearly and destroyed the alloy. It's a planter.
But I'm pulling the good parts from it and sending them to Doug.
Cheers
Using a 4.6 crank and con rods with 4.0L pistons cdb Defender Technical Discussions 27 October 19th, 2014 11:30 PM
4.6 crank,rods and pistons 350 mud ruts For Sale - Parts 5 April 4th, 2012 10:21 PM
4.0 to 4.6 parts? gtg067i Defender Technical Discussions 6 September 11th, 2010 08:40 AM
Crank scoring--WTF? Davis Defender Technical Discussions 9 March 3rd, 2010 12:27 AM
4.0 internals same as 4.6? Neil McCauley Defender Technical Discussions 4 January 17th, 2007 03:53 PM
