300tdi timing cover - Page 2 - Defender Source
Old July 20th, 2013, 03:14 PM
working on this now, need access to a press to push the parts in and out.
Old July 23rd, 2013, 06:43 AM
Swapped the bearing last night. I used a big bearing splitter, a few sockets, a propane torch, and a 12 ton press. Oiled everything up good before squeezing it back together. I used the Jaguar fan idler bearing. Had to cut about 1/4" of the end of the shaft. The bearing body is longer than the LR unit and protrudes into the casing a bit. I tried to show how I set up the press for each push. Also there was a big ass frog hangin' by the pool. Couldn't get the bearing in the pic for size comparison though.
ID:	76323   Click image for larger version
ID:	76325   Click image for larger version
ID:	76327   Click image for larger version
ID:	76329   Click image for larger version
ID:	76331   Click image for larger version
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 23rd, 2013, 10:18 AM
FYI I used Jaguar part# EAC3437. Though, if I had to do it again would just get the one from SA.
Old July 26th, 2013, 06:43 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
Good job!!!
PS: what SA stands for?
Cheers,
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old July 27th, 2013, 07:34 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Just did it myself also this morning. I did use a trick to make my life easier by cutting old bearing in two with a fine disc, splitting it between casing and pulley support.
By doing this you can push out old parts much easier.
- Charles Eames
300tdi, cover, tdi
300Tdi Timing belt failure and repair.. TDI Guy Defender Technical Discussions 46 November 11th, 2010 12:53 PM
300tdi Timing belt tracking Ren Ching Defender Technical Discussions 5 September 15th, 2010 11:32 PM
Timing Cover nikojo Defender Technical Discussions 7 July 5th, 2008 09:38 AM
US source for 300tdi timing belt tool kit D90user Defender Technical Discussions 5 September 5th, 2006 05:35 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
