300Tdi Fan Shroud D1/RRC - Defender Source
Old March 29th, 2014, 10:13 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Need fan shroud for 300tdi D1/RRC
Rent my
Old March 31st, 2014, 09:15 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
anyone?
Rent my
Old March 31st, 2014, 11:31 AM
RoverPaisa
Abel
1988 40th Anniv. RRC Chamonix White
I have a fan shroud from an 89 RRC.
Follow me on Instagram for my adventures @abelbricoleur
IG
My Website:
Abel DLT
Los Angeles, CA
Old March 31st, 2014, 11:37 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
where are you located?
how's it look?
Rent my
Old March 31st, 2014, 11:41 AM
You mean the one for the intercooler and radiator? I have one. Looks like this:
Old March 31st, 2014, 11:47 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
I'm looking for one and the fan as well.
Old March 31st, 2014, 12:52 PM
RoverPaisa
Abel
IG
My Website:
Abel DLT
Los Angeles, CA
Old March 31st, 2014, 01:08 PM
how's it look?
89 wouldn't be 300 tdi. Water pump on ea engine is in a different spot . You need a 300 shroud. I have a defender one you can borrow to see if it's the same. Probably won't need it till mid summer.
Old March 31st, 2014, 01:24 PM
I have one from a defender. Should work fine as engine and rad frame are the same. $30 plus shipping. New ones are $100 @ RN. Will send a photo tonight.
Old March 31st, 2014, 01:32 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Dave, I will take if Nomar doesn't.
Old March 31st, 2014, 02:44 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I'll take it-
That was my next question-size?
I'm still thinking about an electric fan setup but I've got the mechanical right here ready to go.
edited- yes what Doug and Bill said above- I need the shroud with rad and the intercooler on the left side.
Rent my
Old April 11th, 2014, 10:20 AM
http://www.roversnorth.com/ProductDe...36X&type=0&eq=
Old April 11th, 2014, 11:05 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I have fitted a big Zirgo fan into a 200tdi D1 shroud with a relay sensor fitted to the thermostat housing, nice and clean looking
Used three or four of RRC ABS pump rubber mounts to put it together, still has an inch gap around it, but that was the biggest fan I could find at the time.
ID:	92845   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 11th, 2014, 11:41 AM
pendy's Avatar
pendy
jim pendleton
89'd90
The shrouds are different between the D1 and Defender. You do not want to use the defender version in a RRC or disco conversion.
legend in my own mind
Old April 12th, 2014, 09:18 AM
Makes sense, thanks Jim. I think what I had was actually from a Disco 200tdi. I think he'll have problems due to the location of the lower rad hose. If it doesn't work I can take it back or he can sell it forward.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
300tdi, fan, tdi
RRC fan fit Defender shroud? ini88 Defender Technical Discussions 73 August 25th, 2015 04:09 PM
Fan Shroud removal gas-man Defender Technical Discussions 8 June 18th, 2012 10:44 AM
Wanted: Defender 300tdi fan shroud / cowl kylesrover Wanted 3 June 9th, 2012 05:59 PM
300Tdi Fan shroud and fan Buckon37s For Sale - Parts 1 December 18th, 2009 10:46 AM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
