300tdi engine swap - Defender Source
Old April 4th, 2015, 10:33 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
300tdi engine swap
Looking for a complete setup to swap the 19J out of my 110. Would love a 300tdi + trans if possible.
Let me know if you've got something.
Thanks!
-E
Old April 5th, 2015, 09:53 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
And to add, I've got a RHD 110, so any specifics on what parts are required (if you're proposing a swap).
Old July 7th, 2015, 01:53 PM
asif k.
Do you have your 19j engine for sale if you removed it from your defender? Whats the condition of the 19j?
Old July 7th, 2015, 02:55 PM
Thanks!
-E
Two ways to go and well documented here and elsewhere on the web.
200 tdi bolts right in.
300 will require that you do modifications. You could buy a short bell housing r380 from ashcrofts so that you wont need new floors and tunnel and bulkhead adapter inside. The 300 uses different mounts and the frame side mounts have to be welded to your frame. The typical template supplied wont work since you will be mounting the engine further back, if you go with the short bellhousing route to avoid replacing all the above inside. If you opt to go with the normal 300tdi r380 then you will need to replace the floors, tunnel and bulkhead adapter in order to fit the combo.
Did I mention the 200 bolts right in ?
200 is the exact same displacement as the 300 and about 2hp less due to a different turbo design.
300tdi, engine, tdi
Carb rebuild vs FI swap vs engine swap samer0214 Defender Technical Discussions 14 July 13th, 2014 08:33 AM
Engine Swap: which one? 200tdi, 300tdi, or something I dont even know about gonzanc Defender Technical Discussions 46 April 2nd, 2013 09:36 PM
Finished the 300TDI swap - some problems/questions jaherring Defender Technical Discussions 10 February 23rd, 2011 01:37 PM
300tdi swap Ren Ching Smaller Projects 37 October 7th, 2009 08:03 PM
for sale 300tdi engine/box/rad/intercooler/engine mounts ect leachy For Sale - Vehicles 6 September 8th, 2008 08:11 PM
