3.9l rebuild kit - Defender Source
Old November 15th, 2009, 11:09 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
3.9l rebuild kit
I need a rebuild kit for a 3.9l V8. PM if you have one
Old November 16th, 2009, 12:52 AM
CDeWan
Clay DeWan
5.3L beastie
3.9L rebuild
I am currently in the process of rebuilding my 3.9L. Are you looking for name of sources for parts...if so PM me and I can tell you where I grabbing my parts.
Clay
Old November 16th, 2009, 01:29 AM
It is called a 4.6 short block.
Old November 16th, 2009, 12:58 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Land Rover pistons .020 all bearing and LR gaskets 1750.00
Let me know
JP
legend in my own mind
Old November 18th, 2009, 08:41 PM
JohnsD90's Avatar
JohnsD90
I need piston rings, new bearings, and it would be nice to get some really good valve springs.
Old November 18th, 2009, 08:59 PM
pendy's Avatar
pendy
jim pendleton
89'd90
You could have the cylinder head milled and use chevy V8 springs.
Old November 19th, 2009, 12:51 AM
CDeWan
Clay DeWan
5.3L beastie
Try TLR land rover on his special page - he may have much of the stuff you need for the rebuild.
Upgrade your cam shaft gears, chains to a pro-gear set (steel instead of iron) - http://www.aluminumv8.com
Old November 19th, 2009, 09:50 AM
JohnsD90's Avatar
JohnsD90
Thanks, and Pendy i like that idea.
kit, rebuild
Rebuild kit for starter motor ini88 Defender Technical Discussions 1 May 23rd, 2008 04:50 PM
Some gauges/dash pieces/drop arm rebuild kit Hans For Sale - Parts 5 March 12th, 2007 05:41 PM
Read door rebuild hinge kit Image needed ini88 Defender Technical Discussions 3 November 7th, 2006 01:12 PM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
