3.5 heads, or ?? - Defender Source
Old May 16th, 2014, 03:01 PM
3.5 heads, or ??
My '88 RRC with original 99k miles 3.5 is showing 30psi on cylinder #2. All other cylinders show proper compression of 165-170.
My guess is it needs a valve job. But, inside the valve covers is a right mess with carbon buildup everywhere. Guessing I will find similar situation under the valley pan, so, thinking will probably end up doing cam, lifters, timing set, and rebuild or replace the heads.
Would like to not have the vehicle down for too long, so, prefer to source good used or rebuilt heads. I don't think it much matters what they are from. What have you got?
Feel free to suggest other options.
Thanks, DB in DC
Old May 16th, 2014, 03:37 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
FWIW, I plan to get rid of my 3.5 and put a fuel injected 4.2 from a Range Rover in mine.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old May 16th, 2014, 04:03 PM
The RRC 3.5 is higher compression ratio than yours, electronic ignition, and of course fuel injected.
Old May 16th, 2014, 04:10 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
And therefore worth fixing & keeping!
Old May 16th, 2014, 08:19 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Dave -
One thing - 3.5 v8 motors came in a lot of flavors older than your RRC. Older spec heads will fit and work but they will have smaller valves and lower compression (like already mentioned).
If you stick to mostly any fuel injected motor then your heads should a good choice.
When I rebuilt my stage one 3.5 - I used heads from a 3.9 that Tillery sold to me. The valves were noticeably much bigger on the head from the fuel injected motor than my stock carb motor.
In the USA - you are probably more likely to only find newer big valve heads - but I thought I would mention it just to be safe.
Firemanshort
1980 Stage One 109
Sterling, VA
Old May 18th, 2014, 08:21 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I hear these 3.5's are fetching good coin in the UK now. Irony.
Clay
Old May 18th, 2014, 10:44 AM
I have some from a 3.9L. I don't know if they are the same.
Old May 18th, 2014, 11:32 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Clay
I sent the one from my 110 to the scrap metal yard.
Unknown Author
716-898-8153
Old May 18th, 2014, 11:54 AM
I've got a friend coming over today with a borescope so we can take a peek inside the bad cylinder and see what's going on.
swapping heads between 4.0's artm Defender Technical Discussions 3 July 16th, 2006 07:43 PM
Wolf XD mirror heads - anyone using these? solihul Defender Technical Discussions 8 May 18th, 2005 01:03 AM
Redo heads or not? mlw911 Defender Technical Discussions 14 October 21st, 2004 02:42 PM
What do I need to know about rebuilt cylinder heads (non-LR) loykd Defender Technical Discussions 2 October 18th, 2004 10:36 PM
superficial rust on bolt heads 97 SW kevincdoyle Defender Technical Discussions 3 January 3rd, 2004 09:55 AM
