24 spline HD rear axles for 93 RRC - Defender Source
Old August 19th, 2013, 04:46 PM
spaeth's Avatar
spaeth
Craig Spaeth
93 RRC LWB 300TDI
I popped my rear diff and managed to scrounge up a rear diff with a Tru-Trac installed. Problem is my 93 RRC has 10 spline rear axles. I am needing to change out to the 24 spline and would like to do something Heavy Duty. Just thought I would check here first.
thanks
spaeth@gorge.net
Old August 19th, 2013, 04:52 PM
Unless you are running big tires, stock 24 splines should be fine with a TT.
Old August 19th, 2013, 05:36 PM
spaeth's Avatar
spaeth
Craig Spaeth
93 RRC LWB 300TDI
Nothing huge, 245/75/16 with a 300tdi so some pretty good low end torque, but I am more of a finesse driver. Like to pick the right line more than just powering through.
Old August 19th, 2013, 06:24 PM
Just run stock 24 splines then. They are cheap used.
Old August 19th, 2013, 06:45 PM
CDeWan
Clay DeWan
5.3L beastie
if you must go HD try Justin at lucky8llc as he sells the Ashcroft or you could go with GBRs for more money. I am running the Ashcrofts.
Old August 20th, 2013, 08:06 PM
spaeth's Avatar
spaeth
Craig Spaeth
93 RRC LWB 300TDI
I picked up a set of used stock 24 spline and will see how it goes. $150 for those vs $528 + shipping for the Ashcrofts. I know you get what you pay for, but I have not had problems even with my 10 spline so thought I would give this a go first. Thanks for the advice.
Old August 20th, 2013, 08:45 PM
$150 shipped is fair.
Old August 21st, 2013, 11:35 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
x2 I've run stock 24's in my 90 with a TT in the front and Detroit in the rear for 8+ years/80,000 miles with no problems on 255x85's. The advice i took fron GBR early on is to have my shaft be weak link as opposed to the diff/locker.
Clay
axle
GBR HD non ABS rear axles $350 RoverDude For Sale - Parts 5 March 7th, 2013 10:39 PM
Ashcroft HD rear axles and Flanges RRC/D1/D90 ArmyRover For Sale - Parts 1 January 21st, 2013 08:45 PM
D110 rear ARB Locker & GBR HD axles crobinson For Sale - Parts 8 September 3rd, 2008 11:15 AM
Misc- axles, BFG A/T's RRC Alloys, more Shane@EVS For Sale - Parts 1 January 19th, 2006 11:31 PM
