200tdi or 300tdi Engine Cover - Defender Source
Old October 3rd, 2012, 12:20 PM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
Looking for a 200tdi or 300tdi Engine Cover. The rubber one that sits on top of the valve cover gasket.
Jon
Old October 3rd, 2012, 12:24 PM
Ebay.co.uk
Old October 3rd, 2012, 12:27 PM
bitz's Avatar
bitz
Jon
Yeah I was just seeing if anyone local had one first.
Old October 3rd, 2012, 12:45 PM
I'm curious if they are all bling or if they make any difference in sound dampening? I think they might fit a 2.8, but if they are only for bling then I have no interest myself.
Mark Kellgren
KM4BOR
Old October 3rd, 2012, 01:06 PM
Naplm00
Matthew
pure bling, they are 2mm plastic
Old October 3rd, 2012, 01:18 PM
With a high density foam on the underside that signifigantly deadens upper engine noise
Old October 3rd, 2012, 01:31 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
That. I have one but I run without it, when they get wet they will hold the water for a while unless the engine is running till they dry. They give a nice finish touch and significantly lower your engine noise.
- Charles Eames
Old October 3rd, 2012, 03:02 PM
Naplm00
Matthew
ive had 2 but neither had any type of foam on it
Old October 5th, 2012, 03:33 PM
ok, I'm interested now in trying one (with foam)
Mark Kellgren
KM4BOR
Old October 5th, 2012, 05:14 PM
Rugbier's Avatar
Rugbier
Gustavo
You couldn't be farter away from the truth.
On the red 110 200tdi I put the cover, and reduced the noise considerably at idle and high speeds ( well LR high speeds ..lets say 25mph downhill ;-) )
They are made out of rubber not plastic, they are heavy and stay in place on their own weight. ( had a foam underneath the rubber )
Best option I added to the truck
NO SIGNATURE
Old October 5th, 2012, 06:56 PM
That is quite an endorsement!
Mark Kellgren
KM4BOR
Old October 6th, 2012, 07:04 PM
Rugbier's Avatar
Rugbier
Gustavo
Mark, I've ordered it on ebay.uk from one of the usual wreckers, and paid maybe $ 75.00 shipped.
NO SIGNATURE
Old October 6th, 2012, 09:26 PM
I've never seen the foam type either...are those a later model cover?
Also, does anyone know if the Disco and Defender 300Tdi covers are identical?
Old October 6th, 2012, 10:06 PM
foam is glued to underside of a black plastic shell. Shell is pretty soft and flexible itself.
The foam on several trucks I have had has been oil logged which given that tdi valve cover gaskets leak if you don't change them when you adjust the valves every 12k is probably why these covers drop the foam or get thrown away all together.
Old October 6th, 2012, 10:15 PM
The foam on several trucks I have had has been oil logged which given that tdi valve cover gaskets leak if you don't change them when you adjust the valves ever 12k is probably why these covers drop the foam or get thrown away all together.
Off topic, but I replaced my valve cover gasket and still get oil on the cover. Sort of drives me crazy but can't figure out from where...maybe the cap (but I've replaced that too).
Old October 8th, 2012, 09:39 AM
so are there 2 versions? a platic w foam and a rubber? if so, part no's for rubber version.
Mark Kellgren
KM4BOR
Old October 8th, 2012, 11:09 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Do these work on a defender
200tdi with the high Turbo?
Old July 25th, 2017, 08:10 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Trying to find out myself... I bet it will work if you are willing to cut it.
Old July 25th, 2017, 08:19 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Adam,
ERR3276.
LRDirect, Craddocks, etc.
Makes a noticeable difference.
KGH - Defender Snob
Old July 25th, 2017, 08:29 PM
AdamSanta85
91' D90 200TDI
Originally Posted by KGH View Post
Adam,
ERR3276.
Oh man I had no idea that existed. Anyone have a good pic of one?
Is this it?
200tdi, 300tdi, cover, engine, tdi
Brand new 300Tdi engine - in the UK diesel_jim For Sale - Parts 0 July 24th, 2012 02:24 AM
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
300tdi (engine) on ebay Cred The Flea Market 0 May 28th, 2009 11:09 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
