200tdi defender compatible snorkel - Defender Source
Old December 20th, 2011, 09:30 AM
Naplm00
Matthew
Ive got a RHD 110 with a defender 200tdi. Id like to put a snorkel on it. I only have the stock airbox, i am missing the intake tube that would connect to the airbox intake
Old December 28th, 2011, 03:13 PM
Naplm00
Matthew
still looking
Old December 28th, 2011, 03:37 PM
bossman429's Avatar
bossman429
Adrian
1988 90
I have one - will send you a PM
Old December 28th, 2011, 03:53 PM
Rugbier's Avatar
Rugbier
Gustavo
Another option is to put a Mantec NAS snorkel, I have that on my 110 200Tdi
And if your box is on the LH of the engine ( as it should ) you only have to use the short hose from the wing to the air intake box
( IMO is the best solution as it stays out of the way and not a hank of plastic on the side of the wing... but what do I know )
NO SIGNATURE
Old December 28th, 2011, 04:21 PM
Naplm00
Matthew
This is the style that im looking for. I have an early truck so there is no side hole on the wing for the intake. I would like to use the top heater duct if at all possible.
Old December 28th, 2011, 04:26 PM
Rugbier's Avatar
Rugbier
Gustavo
Then call Lucky8 and get a NAS one
When I had Shrek ( no roll cage ) I had a NAS snorkel and I mounted the rings to the Windscreen frame as the holes I am sure they are there already
ID:	45346   Click image for larger version
ID:	45348   Click image for larger version
Name:	home tease 1.jpg
NO SIGNATURE
Old December 28th, 2011, 05:13 PM
Naplm00
Matthew
since my truck is rhd, and the hater box intake is on the rh side and the turbo intake is on the rh side. do i just need a silly long intake tube from the airbox to the opposite side of the truck?
Old December 28th, 2011, 05:16 PM
Rugbier's Avatar
Rugbier
Gustavo
The Mantec comes with both hoses ( long and short ) so yes you will have the set up alla NAS with the hose accross the engine
NO SIGNATURE
Old December 28th, 2011, 10:51 PM
the rover shop
shayne young
Or you could do like the camel trophy 110 did...the intake for a LHD 110 was through the fender but the intake hose for a RHD went through the left rear corner of the hood...that way you could keep the heater box intake runner...
200tdi, snorkel, tdi
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
Adding A/C to a 200tdi Defender dave_lucas Defender Technical Discussions 35 October 3rd, 2015 03:41 AM
Defender 200tdi wastegate / boost tee location dave_lucas Defender Technical Discussions 9 November 18th, 2009 04:18 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Safari Snorkel on NAS Defender BradforD90 Misc. Chit-Chat 7 September 29th, 2004 12:03 PM
» Defender Registry
CTX
4RF RDS
Augi
DaveGilley
Add your Defender
