200TDi crankshaft - Defender Source
Old August 29th, 2013, 10:58 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
200TDi crankshaft
Hi! Have a customers' 110 in for service- the crank pulley had come loose, beat-up the end of the crankshaft a little, another shop fitted a new pulley but the crank damage was too severe. So, it came loose again, beat up the end of the crank and destroyed the keyway. Local engine shop hasn't had any luck welding it up and cutting a new key way.
So, any body have a serviceable crank available?
Email is
Same place, new dogs.
Old August 29th, 2013, 01:19 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
There is a possible work around...
We had a similar issue in December.
If the keyway for crank timing belt drive gear is OK, like this one was, you can have the crank welded and a keyway cut in a different location like the opposite side of the crank for the crank pulley, and replace the crank pulley. We did this because the welded area was just too hard to cut a new keyway into.
Only drawback was that the timing belt drive gear has to go on first, then the crank pulley key, then the crank pulley. Owner was informed and was good with the change.
If you havenít done so already, remove the timing belt drive gear, because most likely the gear and key will have to be replaced, luckily the keyway was OK and we we able to fix the engine as described.
Itís a daily driver in use with no issues so far.
Youíll also need a special tool to lock the crank pulley. We had a bunch made, eBAY item 170964110287.
RDavisinVA
Old September 2nd, 2013, 05:49 PM
atlcruiser
david
many
I got one.
Terrence Anderson
Shipping Manager
URBAN LAND CRUISERS LLC
+44 404 915 1281
Atlanta, GA USA
URBAN LAND CRUISERS + ROVERS LTD
1st Floor, 2, Woodberry Grove
London
N12 0DR
UNITED KINGDOM
+44 020 8133 1557
Company Registration No. 09003009
Our new Vehicle Sales site:
200tdi, crankshaft, tdi
York 210 OBA install 200tdi sonoronos Defender Technical Discussions 69 June 15th, 2014 03:50 PM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
Crankshaft Pulley/dampner Davis Wanted 2 June 28th, 2005 12:12 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
200tdi D110 Camel Trophy 65k Eric Siepmann Misc. Chit-Chat 22 May 26th, 2005 05:16 PM
