2" Receiver Hitch - Page 3 - Defender Source
Old August 24th, 2007, 09:34 AM
That's a me too on the Christian one. I plan to make my own, it's just a matter of finding the time. The 2" receiver can be bought at tractor supply, and I have enough steel plate to make a few of these. Maybe I'll beat rovertyme to it and if I do, I'll consider making additional ones.
charles
Old September 8th, 2007, 10:05 PM
Design opinions wanted
Ok, I picked up a welder last weekend ( a Hobart Handler 175 ) and got some shop time in this evening. I would like some opinions on 2 designs I am considering.
Design goals:
1. Low profile and not reduce departure angle much if any
2. Doesn't need to be able to tow some outrageous load - maybe a small yard trailer, but will be used as the rear recovery point so it needs to be strong.
So I have 2 different designs, each with it's pros and cons.
Design #1
Fits the hitch closer to the frame (sticks out less) but has to be lowered a bit to make it tuck back. After looking at the pictures I realize as shown the gas tank skid probably wont be able to fit back in (has to be removed to bolt this up) but also realized that I can just cut the corner off the 2" piece to allow this. This method of mounting probably doesn't reduce the departure angle much and is less obtrusive. Notice I had to add a "shim" to lower it a bit to make it fit. I might be able to cut more off the 2" tube and remove this... Oh, not shown, but I need to add loops for the chains still.
http://lhsw.com/gallery/hitch/DSC02214
Design #2
This design pushes the hitch rearward so as to resolve any clearance issues with the skid as as a result mounts a little higher. The retaining pin hole has to come in front on the vertical piece. Because it sticks out more, no shim is needed and I can also make a step (see the cardboard mockup) which would not only make it stronger, but I can make slots/holes for the chains in it as well. I think overall this reduces the departure angle slightly more but not much. The idea of having the step is starting to grow on me, making the fact that it is more obtrusive less bothersome.
http://lhsw.com/gallery/hitch/DSC02220
http://lhsw.com/gallery/hitch/DSC02221
All the pictures are here:
Let me know what you think. I hope to find time to finish this up tomorrow (at least welded up).
charles
Old September 9th, 2007, 10:00 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I vote for number 1.
Old September 9th, 2007, 11:44 AM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
#1`is the design that seems best to me.
Gary
Old September 9th, 2007, 12:47 PM
Yeah I think it best meets my design goals. I cut down the reciever tube and have it tucked up without the shim now so I'm happy. But I screwed up my measurements and drilled my holes wrong, so I'm switching to a wider stock plate which will give me enough room for holes for the chain hooks. Will post some pictures later once I redo all my work .
Old September 9th, 2007, 10:03 PM
I never got it completed before running out of time and didn't bother setting up a mockup to show the progress. The only thing left is to make the chain hook holes. My plan is to cut 2 relatively large holes/slots for the hooks, but this is probably the hardest thing to do with my limited tools. I might go back to plan A which was a small loop.
Anyone ever try use a keyhole saw to cut a hole in 5/16th steel?
Actually i think I'll just make a 1/2" hole and hang one of these in it
http://www.marinepartdepot.com/new316ststqu1.html
or
http://www.berkeleypoint.com/product...stshackle.html
Anyone know of a cheap baby swivel shackle (can't remember what they are called)? I've googled but can't find any.
Old September 13th, 2007, 10:57 PM
Ok, finally found time to finish this up (it still needs painting though). I don't have a picture of it test fitted but will add one once painted.
http://lhsw.com/gallery/hitch_final
Pretty happy with the result.
charles
Old September 14th, 2007, 10:49 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
charles
Charles,
It looks great, I like it a lot!
I'll take one. Actually, I'll take the 4th one you make. By then your welds will be spot-on.
Here's my idea for a "receiver" that an assortment of attachments can be mounted onto (pintle, 2", etc). It's just a 3d image, obviously.
ID:	10476   Click image for larger version
Old September 14th, 2007, 06:36 PM
Yeah my welds are not the prettiest but the nice thing about this design is you don't really see any of them
I have seen a design like the one you show somewhere before. What's the advantage over attachments mounted on a 2" shaft? Also on mine I can still mount something like a dixon-bate jaw and still use the 2" receiver.
But that doesn't look too hard to make. What's the width of that channel? I'll keep an eye out when dumpster diving.
Old September 29th, 2007, 10:00 PM
The price differential between a 7,500 lb tow jaw and a 2"bar with a D ring on it wasn't that bad, so I got one and mounted in on the hitch plate as well. Other than the paint chipping easily I'm very happy with end result. I did have to cut a bit off the end of my hitch bar to clear the skid, so I may not be able to use someone else's without the same treatment, ie may not be too useful unless I come prepared, or keep a sawsall in the truck .
http://lhsw.com/gallery/hitch_final/DSC02267
Getting the backing plate in and the nuts on was a pita (but manged to do it without dropping the tank, just the skid). I had to enlist the help of my wife for an extra pair of hands. Having an 8 year old sitting in the back of the truck asking all kinds of questions is optional and discouraged - it's amazing how easily agitated you get after lying on your back for an extended period of time trying to hold things with a screw driver, telescoping magnet and your pinkies (the only fingers that fit between the crossmember and the tank)!
charles
Old September 30th, 2007, 06:48 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Looks pretty nice, now you can tow my trailer for me
Old October 1st, 2007, 08:48 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Nice work, Charles! Now to start mass producing them and you'll retire early!
Old October 1st, 2007, 08:50 AM
OMG, I wouldn't make minimum wage at the rate it took me to make that one!
Old October 2nd, 2007, 04:53 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
And that does not count handling the returns due to disatisfied customers because of the look of the welds! ;-)
I forgot to add: looks great!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 2nd, 2007, 07:06 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
His welds are NOT bad. I have seen much worse. It will just take a little practice and the 175 is a limited machine.
I just looked through this thread, and it reminded me of back when I had a frame. I think the best way to do this by far is to cut out a notch for the hitch and weld in 2in bar. It would be way lighter, just as strong and not hang down at all. But it is a one at a time solution.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 2nd, 2007, 07:29 PM
He's just busting my balls. I probably gave him sh*t about his welds on his sliders he made They may not win any awards, but I think they don't look bad for a first project and are plenty strong.
I think you are right about notching the frame as long as you don't mind the permanence. It would have to stick out somewhat to be able to put the pin in though.
charles
Old October 9th, 2007, 12:55 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Hitch
Here's one for sale in the UK. It has the adjustability that I was looking for, although it may extend a little lower than I would like.
http://www.mailorder4x4.com/acatalog/BA192A.jpg
http://www.johncraddockltd.co.uk/car...sp?prodid=4081
Old October 9th, 2007, 02:05 PM
Would you mount it without that extra reinforcement shown in the picture of one mounted on the truck? If not then it should be ok, but if yes, then it will have worse clearance than the NAS bumper!
Old October 9th, 2007, 02:10 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Yeah, I know, I like the one on the right, but I don't want it to stick down below the crossmember when nothing is attached to it. Nice to know something like it exists though.
Old October 9th, 2007, 02:23 PM
BTW, has anyone ordered from Craddocks? How do they handle shipping and is it reasonable? They say you need to order through the Barclaycard EPDQ credit card system.
http://www.johncraddockltd.co.uk/content.asp?pageID=3
hitch
Winch Holder 2" receiver hitch tomaco1 For Sale - Parts 1 October 31st, 2009 01:24 PM
Receiver hitch suggestions? ajh Defender Technical Discussions 6 May 23rd, 2009 02:01 PM
WTB: Safari Gard (or similar type) - D90 2" Receiver Hitch pmd Wanted 1 April 18th, 2007 02:54 PM
Yakima Roc n'gate (Terra Gate) 2 bike carrier for 2" receiver dmarchand For Sale - Parts 2 November 19th, 2003 10:45 AM
2" receiver options rover4x4 Defender Technical Discussions 1 November 15th, 2003 03:11 PM
