2.8 TGV alternator needed - Defender Source
Old November 7th, 2016, 07:31 AM
anybody have a decent used one before I buy new?
Mark Kellgren
KM4BOR
Old November 7th, 2016, 08:28 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
If you email me a picture, I think we have a 100 Amp one.
RDavisinVA
Old November 7th, 2016, 08:37 AM
very different from the 300 tdi ones. it has the integrated vacuum pump on the back
Mark Kellgren
KM4BOR
Old November 7th, 2016, 08:43 AM
BlackField's Avatar
BlackField
Oscar
D110
That's one of the concerns with my recent 2.8TGV purchase. I'd like a work around for that vacuum pump.
Old November 7th, 2016, 09:44 AM
Yes. That would be nice. It would also require a different turbo oil feed line and return since vacuum shares with turbo.
Is 300 tdi a 7pk belt?
Mark Kellgren
KM4BOR
Old November 7th, 2016, 09:49 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Yes.
Old November 7th, 2016, 09:52 AM
Originally Posted by Mybluett View Post
Yes.
Good. Now this alternator is easy to replace regulator. $50 and flat head screwdriver and your good. I have a cracked mounting ear, so no option other than replacement.
Mark Kellgren
KM4BOR
Old November 7th, 2016, 09:53 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
Can yours not be rebuilt?
Even a cracked mounting ear could be welded.
Old November 7th, 2016, 09:56 AM
It was welded. Broke again
Mark Kellgren
KM4BOR
Old November 10th, 2016, 08:17 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I could be wrong, but the last 2.8 I looked had had a blanking plate bolted on where the vacuum pump would normally live on a 300.
But this doesn't mean that there's anything on the camshaft to operate said pump though, so tell me to shut it if need be.
Old November 10th, 2016, 09:48 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
No problem to source with the vacuum pump.
RDavisinVA
Old November 10th, 2016, 10:24 AM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
We went to hydroboost brakes and obviated the need for the vacuum pump. . .
__________________________________________________
shoefnik wrote: "Itís funny how that moral line you draw for modifying your Rover changes as your needs change."
Old November 10th, 2016, 10:34 AM
I'm thinking maybe i should convert to an electric pump like one below and go with a 300 tdi alternator. Thoughts? Anybody know the amount vacuum needed in Hg for the defender brake booster?
https://m.summitracing.com/parts/sum-760152
Mark Kellgren
KM4BOR
Old November 10th, 2016, 10:50 AM
Naplm00
M
Think it's -12 psi?
Old November 10th, 2016, 11:08 AM
DesertRat
Bryan Barnes
95 D90 2.8TGV
You've probably seen this..but this is M&D eBay site. $$$
Alternator 24v, International 2.8 TGV | eBay
Old November 10th, 2016, 02:42 PM
Thats 24v
Mark Kellgren
KM4BOR
Old April 21st, 2017, 03:57 PM
AgRover's Avatar
AgRover
Adin
1997 Defender 90 SW Badge #2493
2.8 TGV alternator swap to 300 Tdi alternator
Has anyone replaced the 2.8 TGV alternator with attached brake vacuum pump (85 amps) with a higher performing 300 Tdi alternator (100amps or greater) and AN electric vacuum pump mounted elsewhere? If so please post the part numbers required for the swap and any info on where the parts may be found along with any helpful hints to do the work. Thanks!
alternator
Pissed. And Alternator Wiring Help Needed. SMac Defender Technical Discussions 14 July 29th, 2014 12:05 PM
Series III alternator mount needed Mike Sandone Wanted 0 August 27th, 2013 08:43 AM
Alternator for 97 D90 needed 97Ariesblu Wanted 3 May 21st, 2011 07:45 AM
Tdi alternator Uncle Douglas Defender Technical Discussions 11 January 7th, 2011 01:58 PM
Head Bolt with Alternator Stud, Is It Needed? Grover Defender Technical Discussions 6 October 28th, 2008 11:33 AM
