2.8 tdi injection pump - Defender Source
Old September 17th, 2012, 02:06 PM
rayfi's Avatar
rayfi
Derek Moeller
110
Any leads on a used 2.8 Injection pump?
Old September 17th, 2012, 02:15 PM
2.8's are common place in central/south america. you can get parts for them in auto stores down there. you can try Brazil ebay, but it'll be in portugese, so you'll have to translate it. use key words for ford ranger, as well as the MWM part no.
Old September 17th, 2012, 06:20 PM
rayfi's Avatar
rayfi
Derek Moeller
110
Any state side? Upgrading my turbo and it has been recommended I use a 2.8 pump. Just want to see what is available. Thanks.
------ Follow up post added September 17th, 2012 05:21 PM ------
Oh. And you are correct they do have them on eBay Brazil.
Old September 17th, 2012, 10:02 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
I'd be shocked if you needed a new pump. If anything, your current pump just needs to be retuned. Bosch VE pumps can pump WAY more fuel than they are set up for. If you tell a injection shop what your turbo and injector setup is, they should be able to tune it for you. There is a thread about tuning 200tdi pumps somewhere, 300's would be exactly the same.
Old September 17th, 2012, 11:44 PM
skupetz
Gustaf Kupetz
NAS110, HCPU, Disco, Toylander, 2
injection pump
Hey,
I bought a few parts from these guys, ask for Rene in parts.
GUERRA INTERNATIONAL INC.
8158 NW 67 STREET
MIAMI FL 33166
(305) 437-7992
WWW.GUERRAINTERNATIONAL.COM
www.guerrainternational.com/search
WE HANDLE SPARE PARTS FOR ALL BRANDS
REPUESTOS PARA ECOSPORT & FIESTA &THAILAND RANGER & ARGENTINIAN RANGER
Otherwise My diesel guy said the pumps a simple one that he learned how to rebuild pumps on long ago in diesel school...easy. (course that eludes that any diesel guy/gal can)
Owners name is John but the mechanics name is Eric, tell him its the same engine as the one land rover that comes in from time to time, a 110 with a 2.8.
Diesel & Import Auto/Truck Service, Inc.
9102 Isanti Street NE
Blaine, MN 55449-4358
Phone: (763) 780-2570
Fax: (763) 780-8321
dieselimport@qwestoffice.net
Cheers, -Gustaf
ps I just reread your post, this may not apply, happy hunting.
Old September 18th, 2012, 12:42 PM
rayfi's Avatar
rayfi
Derek Moeller
110
I'll share a little more information.
I have a 300 Tdi the I am putting a larger turbo on. The injection pump on the engine needs to be rebuilt (shop says about $850.00). It was suggested that since I am putting the larger turbo on and I basically need a new pump I may as well try to find a pump off a 2.8. If I can I'll use it if not I'll rebuild mine.
Thanks for the help.
Old September 18th, 2012, 01:42 PM
I don't even know what the difference would be between the two, but it can't be much. there's a few guys including Keith Kreutzer on here that put 2.8 turbos on their 300's with no issues, retaining the 300 TDI IP. I would stick with that pump as it can be worked on per the LR manual, versus something completely different that has no documentation for a shop to follow.
tdi
Tdi Injection Pump Leak Wolf Fabrication Defender Technical Discussions 18 January 2nd, 2012 03:34 PM
200 Tdi injection pump settings ... Retrofit Defender Technical Discussions 0 March 22nd, 2010 10:19 AM
200 Tdi injection pump removal ... Retrofit Defender Technical Discussions 3 October 28th, 2009 01:29 PM
harness on 300 tdi injection pump Abrooks Defender Technical Discussions 5 February 22nd, 2009 12:27 PM
