2.5 N/A engine weld on frame mounts needed - Defender Source
Old April 2nd, 2015, 03:54 PM
basscatn1
Carl Holt
1984 110 County
Hello all from Germany! I am in need of the diesel engine chassis mounts that are welded onto the frame for the N/A diesel. I currently have a 300tdi in the 110 and putting back the original engine to bring back to the states with me. Cringe.
Let me know if you have any and I can pay by paypal if legit purchase.
Old April 2nd, 2015, 04:00 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Find a local fabricator to create some bolt on mounts so you can swap back to a 300tdi at a later date.
Old April 2nd, 2015, 04:22 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You could YRM in the UK, I did'nt see them listed but you never knows
Marsland or Richards chassis as well in the UK
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
basscatn1
Carl Holt
1984 110 County
Those are nice mounts but trying put back "unmodified" hence weld on. I tried ebay in the uk with no luck. I will keep those in mind though as last resort.
Old April 2nd, 2015, 04:31 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Bolt on or weld on mounts will not be an issue…
Production date, motor type, fuel type, drive side, original chassis VIN - things that are decoded from the VIN are what you need to be concerned about for import.
Old April 2nd, 2015, 04:33 PM
rovertrader's Avatar
rovertrader
Dale
I think I have a set- let me check...
Old April 2nd, 2015, 06:26 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
if not I do.
Old April 3rd, 2015, 02:52 AM
basscatn1
Carl Holt
1984 110 County
mounts
Thanks all. I will check with YRM and Richards for mounts. Even if they are not bolt on I could get some backing plates and weld them to and then bolt on. Good Idea.
If you all have a set of the mounts let me know in case the places above don't have them or unreasonably high cost.
The USPS is the only way to ship over here so the one size fits all priority box is the only way to go for those to ship.
Thanks again
Old April 10th, 2015, 12:28 PM
basscatn1
Carl Holt
1984 110 County
Frame mounts needed now in a bad way!
Okay all, I have tried the recommendations for the UK to fab some up and nothing. If you all have any laying around the shop please let me know if you want to sell them. I am down to almost 90 days and have to execute this pretty qwikly!
Old April 10th, 2015, 01:03 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If you are also swapping in a short belhousing 5 speed, you can keep the 300TDI mounts in place and then use a pair of bolt on 2.5 mounts that can be later removed when and if a 300TDI goes back in.
Any metal fabricator could turn you out a pair in half a day or less.
Wish I had some lying around, but I don't.
RDavisinVA
Old April 10th, 2015, 01:13 PM
an alternative to looking in the US for used mounts when you are in europe is to simply buy the frame mounts. They are readily available directly from most and Defender parts purveyor. Just bought some V8 ones to put a gems v8 in an old tithonus truck.
Old April 10th, 2015, 01:18 PM
basscatn1
Carl Holt
1984 110 County
Okay so the V8 mounts will work as well? I have seen those advertised also some 200 tdi fabbed mounts. I can check those out and get them welded to a backing plate to bolt to the frame.
Uncle Douglas can you give me your source for the mounts?
Appreciate the assist
Old April 10th, 2015, 01:21 PM
Uh no. Point was just go buy the mounts they are readily available. 200 tdi and 2.5 natural all use the same mounting bracket, as do the 4cyl gas engines.
engine, mount
300 tdi weld on frame mount pendy For Sale - Parts 5 October 26th, 2016 07:06 PM
300 TDI weld in motor mounts Oliver Whiting For Sale - Parts 13 April 1st, 2014 09:12 AM
Tranny Mounts, 4cyl engine mounts, Tub tomaco1 Wanted 0 December 4th, 2010 12:42 PM
Where to buy 2.5 NA diesel weld in motor mounts? dave_lucas Defender Technical Discussions 15 July 26th, 2009 10:18 PM
weld on motor mounts pendy For Sale - Parts 3 September 8th, 2004 03:10 AM
