2.5 - Defender Source
Old September 23rd, 2012, 01:47 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Potentially looking for an inexpensive 2.5 TD or NA Diesel for parts. Tearing into mine shortly, and as this is the shop truck I'm not looking to spend much to keep it running in the short term. She will get the full frame-off rebuild treatment next year after the other projects, but the smoke continues and I fear the worst.
Any leads are appreciated.
Old September 23rd, 2012, 01:55 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
old NA diesels almost always smoke. what kind of smoke is it? what parts are you looking for?
Old September 23rd, 2012, 02:10 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
I'm guessing there are top-end issues. White smoke at idle, varying between moderate to cloud cover, gray smoke with compression, oil into the air filter, and after running a top-end cleaner i've now got a leak near the oil pump and it tried to run away on me when pulling into the shop. Low power and the fact that the PO overfilled the oil by 2qt doesn't bode well either. I'm expecting worn rings/pistons as the engine has a tick under 130K on the odo, lifter seals at least.
Cleaned up the shop yesterday so that I can dig into it a little today and tearing it apart next week. I'm not well versed in the weak spots on the Td as all my other engines are 300Tdi, but everything I've heard says there are potential block issues to be concerned about.
Old September 23rd, 2012, 02:35 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
People talk about the early 2.5 td engines having weaknesses but I have seen them do well over 200K with no issues when looked after properly. Oil in the air filter will obviously cause it to run away on you. I would check compression and if ok re time the injection pump before giving up on it.
Patches are for Pirates and pants, not a bulkhead and chassis!
Old September 23rd, 2012, 09:38 PM
tpond
Toby Pond
110
I have a late 2.5 TD that I would sell cheap. I am just down in Portland. Send me a PM.
Old November 9th, 2012, 09:42 PM
Axel's Avatar
Axel
jack
1987 Defender 110 5-door
2.5 for sale
Mine from a 1987 110 is for sale. Complete, even clutch. Runs fine. Removed it for a 200Tdi.
Old November 9th, 2012, 10:07 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
PM sent
Old November 9th, 2012, 10:34 PM
Axel's Avatar
Axel
jack
Got it & replied
Jack
2.5 na diesel in a 110- Advice? TCarawagon Defender Technical Discussions 6 March 20th, 2012 08:11 PM
91 Ex-Mod D-90, 2.5 diesel for sale DaveG For Sale - Vehicles 10 February 7th, 2006 01:10 PM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Anyone know where I can buy an OEM exhaust system for my 2.5 RHD NA Diesel in the USA solihul Defender Technical Discussions 5 October 7th, 2005 02:08 PM
Help wanted: Difference between RR 2.5 TD and 2.5 DSE lakis Defender Technical Discussions 0 November 17th, 2004 10:23 AM
