2.5 / 200Tdi power steering pump - Defender Source
Old October 4th, 2016, 10:25 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
Looking for just a pump - no bracket needed - anyone have one kicking around in usable shape?
2.5 diesel or 200Tdi would both work I think.
Thank you all,
Old October 4th, 2016, 11:38 AM
Naplm00
Matthew
Robert Davis is working on a Mercedes product no search for these engines.
I say this because I had a failing 200 pump and rebuilt it. Lasted a year. Bought new and its on its way out again about 3 years later
They just plain suck
Old October 4th, 2016, 12:10 PM
transientmechanic
1972 SIII
I have a saginaw pump that I was going to make a bracket for but I'm just too lazy.
Old October 4th, 2016, 01:48 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
I have a used 2.5 PS pump that was working when removed.
Let me see if it goes with a complete setup or is just the PS pump itself.
RDavisinVA
Old October 5th, 2016, 10:43 AM
transientmechanic
1972 SIII
Thanks Robert let me know!
Old October 5th, 2016, 01:17 PM
110Landy
Paul
1984 110 2.5D
I have the old one from my 2.5NA. It leaks badly but works. I figured I would try to rebuild it at some point for a spare. Probably not what you are looking for but let me know if you are interested.
Old October 5th, 2016, 02:24 PM
Ignotus
gene
1960 109, w/200TDI
There was a couple of different models. They had different hose fittings. 1 has a bit nut looking thing on the side and the others have a banjo bolt going in from the rear. some had a circular pulley flange and others a triangular one. IIRC the 200 has a longer nose so the pulley sticks out farther.
ETC 9077
ETC 8287
ETC 9070 All fit early 110's but with the different hose fittings.
I have 1 each of the one with the nut on the side and with the banjo on the back.
Gene
1960 109
1960 88 Ignotus
Blog;
200tdi, tdi
200Tdi power steering pump banjo bolt size transientmechanic Defender Technical Discussions 1 January 7th, 2015 09:44 AM
WTB: Defender 200Tdi Power Steering Pump Bracket John_Karlsson Wanted 1 April 29th, 2013 10:06 AM
Disco 200tdi Power Steering Pump Wolf Fabrication Wanted 0 February 5th, 2010 03:53 PM
200tdi power steering pump tomaco1 Defender Technical Discussions 1 August 25th, 2008 10:43 AM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
