14 CUX Defender Coolant Temperature Sending Unit - Defender Source
Old May 14th, 2014, 09:32 AM
I'm looking for a coolant temp sending unit for a 95 NAS D90. I've ordered three through the parts department here at the dealership and they are all the wrong resistance, so I'm looking for a good used one now.
Thanks!
Old May 14th, 2014, 09:38 AM
Originally Posted by Jymmiejamz View Post
I'm looking for a coolant temp sending unit for a 95 NAS D90. I've ordered three through the parts department here at the dealership and they are all the wrong resistance, so I'm looking for a good used one now. Thanks!
Great to know LRNA offers such quality products ... ;-)
Old May 14th, 2014, 09:39 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Are they same as 95 3.9 disco's? If so I might have one or ten
Old May 14th, 2014, 10:29 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
I think I kept mine when I switched over to VDO. I'll check tonight and let you know.
Old May 14th, 2014, 10:52 AM
Nope, I think that's what Land Rover is sending me. The ones I'm getting read about 500 kilohms IIRC. Basically it causes the temp gauge to read all the way hot when warmed up. The original one in the truck had an open circuit. I've already tried another gauge and wired it externally to verify.
------ Follow up post added May 14th, 2014 10:53 AM ------
You get what you pay for!
I'm pretty sure your original would have worked with the VDO gauge. Thanks!
Old May 14th, 2014, 10:59 AM
The Defender and Disco gauges are different ranges. To be clear you are looking for the sender for the gauge and not the 14CUX ECU, correct? The ECU uses a separate temperature sender.
I believe you want PRC2506 Any of your favourite Rover parts suppliers should have one.
Old May 14th, 2014, 11:05 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I put a new Sender in when I installed my VDO gauge. I thought you needed to.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old May 14th, 2014, 11:08 AM
Item 14 is the gauge sender, PRC2506 for a 90 with a 3.9.
Item 20 is the sender for the EFI ECU, ETC8496.
Old May 14th, 2014, 11:10 AM
Yes, the VDO gauges use a different range sender.
Old May 14th, 2014, 11:29 AM
bradfordish
Bradford
95 D90 SW #141
Yeah, you need to. I tired it first without the vdo sender and the needle went to it's max temp reading.
Old May 14th, 2014, 11:42 AM
Jimmy upgrade to a VDO setup ...
Old May 14th, 2014, 12:19 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I scooped a VDO temp gage here but haven't installed it yet. What is the sender part # for a 94' with the VDO if the OEM sender is not?
BTW - my current OEM sender and gauge work fine.
Old May 14th, 2014, 12:20 PM
For the VDO sender, it is either 1/8" NPT or M16x1.5 I was never clear when the change happened with the V8s.... Anyway, look to see what you have first. M16 is a lot bigger than 1/8" NPT.
Any 2-1/16" gauge will fit. VDO Vision series has the best look for the Defender, IMO.
Old May 14th, 2014, 01:39 PM
I will do that when the speedometer fails and I will replace all of the gauges. I don't like the orange needle on the VDO vision series.
I guess I was mistaken about the sending unit for the VDO gauge. I was thinking I didn't replace it on my 300 tdi, but now I'm remembering that the previous owner installed that gauge.
------ Follow up post added May 14th, 2014 01:40 PM ------
That's what I've been ordering.
Old May 14th, 2014, 01:46 PM
You have a 3.9? The manifold looks like the picture?
Old May 14th, 2014, 01:49 PM
The Disco/RR one is PRC7918.
What exactly is making you think the one you are getting is wrong? Have you tried ordering from a non-dealer?
Old May 14th, 2014, 02:06 PM
I've checked the resistance of two other 94/95 D90's and both had the same reading which is different than the ones I'm getting through Land Rover. I haven't tried getting one through anyone else, I work at a dealer. I figured I'd check for a good used one before I order another new one that might not be right.
------ Follow up post added May 14th, 2014 02:08 PM ------
And no, I'm not using Microcat, I'm using the actual book for the part number which is PRC2506 and that is how it is packaged.
Old May 14th, 2014, 02:16 PM
I would order an aftermarket one then. They are not exactly expensive. http://www.roverparts.com/Parts/PRC2506
Old May 14th, 2014, 02:41 PM
It is possible that a 240-33 ohm range gauge may work or be close.
Old May 14th, 2014, 02:44 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
I've have new lrna sensors bad ask geoellis...
No Mall crawler here
coolant, defender
Temperature sending unit jjstahl3 For Sale - Parts 0 June 24th, 2012 05:17 PM
Water temp sending unit 4.0 97-D90-736 Defender Technical Discussions 5 March 24th, 2011 03:42 PM
Temp sending unit 3.9L vs 300TDI - different range? jaherring Defender Technical Discussions 8 October 4th, 2010 08:22 PM
Oil Pressure Sending Unit 61rover For Sale - Parts 1 September 24th, 2009 10:24 AM
Need Oil light sending unit, 97 90 or Disco Tom Fitzgerald Wanted 2 April 14th, 2007 10:57 AM
