10 Spline - Defender Source
Old February 22nd, 2015, 10:10 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
10 Spline
Anybody have a 10 spline true trac front diff, I am still running 10 spline in the front which is all been rebuilt and is tight. But would like LSD, rear has arb locker.
Or I am going about this wrong?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 22nd, 2015, 10:15 AM
why do you ask if you're going about it wrong?
Old February 22nd, 2015, 10:28 AM
roverman2010
1985 LR 90 200Tdi
Meaning should I go all 24 f&r, I am thinking that the later 10 spline stuff is stronger or equal to 24.
I dont like changing stuff for change sake.
And my total budget for this complete restore plus purchase price is getting close.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old February 22nd, 2015, 10:32 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
If you put a true trac in the front with 10 spline axles is only a matter of time before you shear an axle shaft right at the splines. Been there, done that. Plus your truck will resist when turn corners. The true track like to go straight. Put the ARB in the front and the true trac in the back or better yet a full on Detroit locker in the back. Get some upgraded 24 spline axle in the back first, then in the front if you can afford it. Ditch all your 10 spline junk.
Old February 22nd, 2015, 10:39 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I may actually have a 10 spline Trutrac that I never got around to putting in my RRC---went with ARBs.
Its a complete 3rd so its heavy...
I can check if you're interested.
Rent my
Old February 22nd, 2015, 11:18 AM
If cost is an issue, I would really just rethink whether you need anything in the front or not. Especially with an air locker in the rear.
Is this going to be a rock crawler? Or do you just want "insurance"?
Old February 22nd, 2015, 11:37 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
yes, if you just want a little added no-stuck insurance, then stick a trutrac in there.
Rent my
Old February 22nd, 2015, 11:47 AM
I went thru this not to long ago. I purchased a Disco 24 spline axle and then was told the 10 spline front axle was a better choice. I'm slowly rebuilding the 24 spline and will use it as a spare if I break the 10 spline.
Old February 22nd, 2015, 12:27 PM
The better choice is to get a 24 spline TT. You can get them used fairly easily. If new get an Ashcroft ATB. Then get 24/23 spline shafts and you should be good.
The later 24 spline axles require the CVs to be changed as well so are not a good starting point.
Rear Axle: 10 Spline to 24 Spline Conversion / Seal Refresh / Ashcroft Locker Install sonoronos Smaller Projects 44 February 27th, 2015 05:20 PM
36 spline versus 48 spline steering wheels transientmechanic Defender Technical Discussions 31 November 13th, 2013 09:57 PM
Stock 24 Spline Diffs willtillery For Sale - Parts 0 September 6th, 2004 09:21 PM
Need 10 Spline Pass. Side Front Axel... h2eater Wanted 3 August 14th, 2004 09:57 PM
TruTrac, 24 Spline Shafts, CVs mudrover For Sale - Parts 6 June 15th, 2004 05:29 PM
