1 wheel spacer - Defender Source
Old January 1st, 2013, 04:32 PM
Abrooks's Avatar
Abrooks
Tony Brooks
1 wheel spacer
I won't get into my experience today with a paddock spares rear tire carrier, but I need one wheel spacer, thickness doesn't matter.
Anyone?
Old January 1st, 2013, 04:41 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
For your spare mount?
Hardware store --> 3 steel shaft collars.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 1st, 2013, 04:43 PM
Abrooks's Avatar
Abrooks
Tony Brooks
The issue appears to be that paddock used bolts that have different threads than rover lugs, so until I can get some input from them the easiest solution appears to be to use a spacer as an adaptor.
Old January 1st, 2013, 05:10 PM
fwiw. Paddocks is a re-seller. They don't manufacture anything.
Old January 1st, 2013, 05:29 PM
spartan's Avatar
spartan
Fred
83 D110
I bought a rear tire carrier from them and it works with LR lug nuts.
Old January 1st, 2013, 05:49 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Oh, ok. Didn't get what you were trying to do.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 2nd, 2013, 05:20 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I had a customer with a stud that pulled through a spacer. I kept it around to show people why spacers are not a good idea.......might still have it and I'll look today.
Never run into that issue with a tire carrier. Had many issues with several UK vendors of late though.
Matt Browne
Old January 10th, 2013, 01:18 PM
Abrooks's Avatar
Abrooks
Tony Brooks
After going back and forth with Paddock on this, they suggested I go and find bigger washers which obviously wouldn't resolve the issue that the bolts they used aren't compatible with Rover lug nuts. I've ordered one spacer to act as an adapter but would encourage folks to be very careful ordering this or other one-off products from Paddock.
ac, wheel, wheel spacer
Wtb one d-90 wheel spacer dbj2003 Wanted 2 July 10th, 2011 11:42 AM
Wheel spacer help needed isleofbones Defender Technical Discussions 11 April 19th, 2009 08:17 PM
1" wheel spacer - borrow Jase Defender Technical Discussions 0 July 16th, 2005 05:23 PM
255/85 wheel spacer experience D90user Defender Technical Discussions 6 July 13th, 2005 11:12 PM
