1.4:1 LT230 needed ASAP - Defender Source
Old October 28th, 2009, 03:03 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
who says you can't blow an LT230? 5 years with an underdrive will do it.... catastrophically.
prefer 1.4 ratio, will consider a 1.6. needs to have 26 tooth input gear.
muddyrover AT roadrunner.com
Old October 28th, 2009, 03:24 PM
cdb
Clark Bowen
email sent
2011 RR HSE -
2001 GMC 2500 4wd
Old October 28th, 2009, 04:23 PM
I got one out of a NAS 110. Input gear splines are worn. I have $350 into it, yours for that price.
Old October 28th, 2009, 04:28 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
Originally Posted by cdb
email sent
hey clark, i don't see your e-mail.
muddyrover at roadrunner.com
i don't really have time for a rebuild, but if i can't find anything else it might have to do. i'll keep it in mind bud.
rovertrader's Avatar
rovertrader
Dale
Got one, '97 D-90 w/ 40k on it, $500, will go out tomorrow...pm is best
Old October 28th, 2009, 04:31 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
pm sent
Old October 29th, 2009, 01:49 PM
cdb
Clark Bowen
I have a good 1.6 t-case with cross-driiled input shaft and it has the 26 tooth input gear you need for the underdrive.
With 35" tires or bigger I think the 1.6 and an underdrive is an excellent combination, but with smaller tires I'd use a 1.2.
$350 plus shipping.
Clark
2011 RR HSE -
2001 GMC 2500 4wd
Old October 29th, 2009, 01:57 PM
It takes 5 minutes to replace the input gear.
Old October 29th, 2009, 03:27 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
ok... dale's is the wrong tooth count... still looking. Ron, is your's 26 tooth? if you think everything else looks good through the inspeciton cover, i'm not going to use the Rover input gear anyway.
i'll pm you my phone number.
Old October 29th, 2009, 03:28 PM
Pretty sure it is 26 tooth which is what came stock in a 1993 NAS 110. I can pull the inspection cover if you want.
Old October 29th, 2009, 04:05 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
I just pm'd you.
it HAS to be 26 tooth or it won't work for me.
$350 plus shipping.
Clark
I've got a 1.4 now and kind of like that ratio with my setup. Ron is going to pull the inspection cover on his 1.4 and give it a looksee for me. if it dosn't look good, i'll be going with your 1.6.
Thaks guys.
Old November 3rd, 2009, 04:06 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Does anyone have just a 26 tooth input gear? I need one
Legend in My Own Mind.
Old November 5th, 2009, 05:16 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
i have a like new cross drilled one that i pulled 5 years ago from a 35K mile case when i put in my underdrive...
have the pto cover, shim, and matching bearing race, too.
not sure what the going price is... how about $125 plus shipping for it all?
Old November 6th, 2009, 08:20 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ok. I will et you know asap. what tooth count is in a 1.2 case out of a 95 d-90?
Old November 6th, 2009, 09:49 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
if in doubt, count.
Old November 7th, 2009, 11:26 PM
cdb
Clark Bowen
it won't be 26 tooth unless it was modified. The 1.4 D110 or the 1.67 t-case have the 26 tooth and they match up for an underdrive.
2011 RR HSE -
2001 GMC 2500 4wd
Old November 8th, 2009, 09:48 AM
mattm's Avatar
mattm
Matthias Moran
1963 109
If you're keeping your underdrive then you won't be using the input gear right ?
So it doesn't matter if the splines are worn. (Or am I misunderstanding how these things fit together.)
Old November 9th, 2009, 05:58 AM
Lyman
Lyman Saltsman
1987 Rokon Ranger
right-o matt. normally i wouldn't have screwed with a case that has gotten to the point of spline wear though, but pickins were slim for a 1.4 and i no longer throw wads of cash at this thing like i used to.
what i throw wads of cash at now: mine is the blue one.
http://www.youtube.com/user/jettagli...13/P3Y1tnvm8IM
thanks ron, t-case is in. guts looked surprisingly good. i have a more wine on overrun than normal, but very quiet while in the throttle. gear lash looked good, so i think it's just two diffferently worn gears getting to know each other. ran it around for an hour or so, seems to be quieting down.
check in the mail today.
Old November 9th, 2009, 10:41 AM
Thanks Lyman. She seemed nice inside when I pulled the cover.
Ron
BTW for future reference, spline wear happens very early on (like 30k) and has zero impact on the rest of the case. The downside with spline wear is buying the expensive cross drilled input gear to fix it.
lt230
Needed ASAP flippedrover Wanted 10 December 28th, 2007 04:36 PM
LT230 locking linkage needed pcarey Wanted 2 July 23rd, 2007 01:11 PM
Help needed ASAP Mapsource GPS Euro SafariHP Misc. Chit-Chat 0 September 18th, 2006 02:12 PM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
underdrive for lt230 boxerhips Wanted 1 October 9th, 2003 10:00 PM
