1.2 gears for lt230 - Defender Source
Old May 24th, 2016, 01:53 PM
stancey's Avatar
stancey
steven stancey
1988 Defender 110 LS, 1993 130 tdi
1.2 gears for lt230
Hey everyone, in an effort to make my v8 110 more highway friendly, I'm looking for the 1.2 gear setup for the lt230. Let me know what you have. I believe the 95 disco might have the correct gears. Thanks
Old May 24th, 2016, 02:06 PM
jafir's Avatar
jafir
Jafir Elkurd
Pretty much all NAS discos will have 1.2. Do you have 1.4 now? I know someone that is looking for that and would probably have a D1 or D2 transfer case to trade.
Old May 24th, 2016, 02:23 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I have a tcase we can trade for...
Old May 24th, 2016, 06:12 PM
stancey's Avatar
stancey
steven stancey
I wanted to keep my current transfer box in case I don't like it, so I would be looking to just buy and not trade. If it works out well, then I would sell what I don't need...
Old May 24th, 2016, 06:40 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
$125.00 for tcase without front or rear output housings...plus shipping
Tcase is off a 2001 d2 (80k) with 38 tooth input gear(quieter)
Old May 24th, 2016, 08:21 PM
Steven: Check your local salvage yards. LT230s go pretty cheap
Old May 24th, 2016, 10:52 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Originally Posted by mongosd2 View Post
$125.00 for tcase without front or rear output housings...plus shipping Tcase is off a 2001 d2 (80k) with 38 tooth input gear(quieter)
This is the way to go, source a LT230Q and the just use your front/rear housings to move over the bits that tend to be different.
Old May 24th, 2016, 11:14 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I did just that.
If the shipping is a pain on Mongos LT230 you can try car-parts.com for something closer.
Old May 25th, 2016, 09:01 AM
stancey's Avatar
stancey
steven stancey
I'll make some calls to the local yards today. We'll see what I can find.
Old May 25th, 2016, 12:22 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I recall Lav's experience at the Yard. Dropping one out in a field vs. paying for shipping on a low mileage unit is something to think about.
Old May 25th, 2016, 12:36 PM
stancey's Avatar
stancey
steven stancey
Yeah, I thought about that. I may just wait around a bit and find a trashed disco locally from 94-95 and buy it, then pull the 3.9 / efi also. I've never fully rebuilt an engine before and it might be fun to take my time without having the car apart on the driveway... Winter project....
Old May 25th, 2016, 12:40 PM
1of40's Avatar
1of40
1of40
Makes sense. Especially buying a running truck that hopefully has all you'll need to do a complete conversion. Should save time and your last nerve. .
Old May 25th, 2016, 02:06 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
If you install a LT230 from an automatic onto a manual, you have to remove the neutral solenoid to use low range. Several threads here about how to do it. Also be careful that some D2 don't have the differential lock.
Defenders draw attention. Don't buy one if you're shy!
Old May 25th, 2016, 02:43 PM
stancey's Avatar
stancey
steven stancey
I was going to ask that. If I find a disco that is automatic, I can still use that in mine??? I would probably cannibalize the disco box and take just the 1.2 stuff that I need. If I do that, the solenoid or diff lock shouldn't come into play, right?? Ashcroft has a great step by step on their website that outlines the gear change. What year do I draw the line? I know 94-95 disco's have the lt230 with the 3.9, but I'm not sure what else would fit that is nas. Thanks everyone..
Old May 25th, 2016, 03:00 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I think you are over complicating this…the biggest problem with swapping the gears is finding cases with the same input gears. You can't use a gear set from a 2001 tcase in one from 94 or 95.
Find a case with low miles, if it doesn't have the CDL nipple on the front housing, just swap yours onto it…
If it has shift solenoid, just pull it, it's useless
Old May 25th, 2016, 03:10 PM
1of40's Avatar
1of40
1of40
or call Ashcroft and get the set shipped to your doorstep
Old May 25th, 2016, 09:01 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
I believe any LT230 (all Disco I & II and others) will bolt into your Defender. Swapping parts into your box, more limited.
Read starting at message 23 for how to remove the solenoid.
http://www.defendersource.com/forum/...o-69423-2.html
Old May 25th, 2016, 09:37 PM
Yes. There is a stub connecting the auto to lt230 (afaik), that will need removing.
I reused my D1 drivetrain in my build, only part needing replacement was the tbox to rear axle propshaft.
Old May 25th, 2016, 10:44 PM
Listen to Frank. 230's are cheap as chips. You have to pull the case to pull the intermediate shaft and change the gear ratio so it really makes little sense to buy the gear set and pull one apart when you can buy another transfer case for short money.
Old May 25th, 2016, 10:48 PM
stancey's Avatar
stancey
steven stancey
Cheap as chips. That's a new one. Is that British??? I'll start looking for the series 1 disco.... Thanks
lt230 tcase mount rhs (disco lt230) Cajun Wanted 8 October 14th, 2015 06:30 PM
how tough is it to replace 1.22 LT230 gears with 1.4 gears cdb Defender Technical Discussions 13 January 5th, 2015 05:28 PM
LT230 1:4 gears veefly Wanted 12 May 18th, 2014 04:13 PM
1.4 LT230 gears Jake1996d1 For Sale - Parts 9 September 24th, 2012 11:05 AM
LT230 with 1.4 gears or just the 1.4 gears!! El Solis Wanted 3 May 13th, 2011 07:56 PM
